Old 06-24-2005, 09:14 AM   #1
ronan1975
Member#: 72380
2009 F-150
Green
Default I'm beginning to hate my wrx - Lemon Law?
All sorts of things are starting to go wrong. I only have 25,000 miles and the only mod is an STI cat back. The A/C went out a trip to Houston. All the pipes iced up, once it thawed out it now cycles between cold air and outside air. Also it's starting to grind going into 4th about 30% of the time. The worst thing is I have had a creaking /groan in my suspension which I have taken into Subaru of Austin 6 times and they can't fix it. I'm going to see the district manager on Monday to "discuss" the suspension.
If it's having this many problems with only 25k on it, what’s it going to be like with 60k+ ???
They have also had to replace the clutch cylinder, fixed the accelerator pedal that was flapping around when you pressed on it, the plastic under the car also fell off, and finally the bezel on the inside of the car is starting to change color.
Is this normal? Is everyone else having these annoying problems? Does the suspension fall under the lemon law?
ronan1975 is offline   Reply With Quote
Old 06-24-2005, 09:20 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
you need to reasearch lemon law - much more in depth
your car does NOT qualify....
http://www.lemonlaw.bbb.org/
AC went out? = get it fixed. it happens.
Grinding in 4th? = likely the way the car is driven
Groaning in suspension? = welcome to Subaru
sorry... but i'm not hearing of any major issues from you really.
nothing anyway that cries.... lemon law
jamie
www.subiegal.com
Old 06-24-2005, 10:00 AM   #3
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Why did you make two threads on the same topic?
Need more information. Did you purchase it used? What is your driving style? Nothing sounds serious to me and definitely doesn't fall under the lemon law.
conker69 is offline   Reply With Quote
Old 06-24-2005, 10:31 AM   #4
ronan1975
Member#: 72380
2009 F-150
Green
One of the posts was in the general forum but the moderator moved it here. I drive normaly , I don't redline constanly or autox and no street racing.
Old 06-24-2005, 12:31 PM   #5
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
They can't fix the suspension, or they can't duplicate the problem with the suspension. There is a difference.
As stated already this is not a case for Lemon law.
Grinding going into gear? Do you have synthetic gear lube in there? If so you brought this upon yourself.
If not this may be related to the clutch slave cylinder (damage done prior,just now showing up)
A.C issue? IIRC there was a tech tip (or maybe a bulletin I can't remember) in regards to the lines freezing up. I believe the fix was to install a different thermal switch on the evaporator.
Last edited by Hondaslayer; 06-24-2005 at 12:35 PM. Reason: Did not catch the slave cylinder having been replaced.
Old 06-24-2005, 12:36 PM   #6
Hondaslayer
Brain Stew
Member#: 4562
BTW the underguard falling off was probably due to the people that changed your oil not tightening the bolts down.
Old 06-24-2005, 12:36 PM   #7
Hondaslayer
Brain Stew
Member#: 4562
Plastic bezel being discoloured is due to interior cleaner overspray.
Old 06-24-2005, 12:46 PM   #8
Stanley
Member#: 7374
2007 MazdaCopMagnet
dusty
FYI - according to my dealer there are "upgraded" parts available for the fourth gear syncro. When I complained of a defective first gear syncro in my 2002, the service tech also noticed grinding in fourth. The syncros on first and fourth were replaced under warranty.
A groaning suspension and discoloration on the interior bits is par for the course. You bought a Subaru, not a Mercedes. Frankly, even if you had bought a Mercedes, you might still be having these types of issues. FWIW, my last two cars (honda and BMW) had inferior build quality as compared to my WRX when it came to suspension bits and the Honda was much worse in terms of the interior.
When meeting with the district manager, remember to be cordial and professional. State only facts, and don't go in with a chip on your shoulder. This approach is best for everyone involved, and will definitely yield the best results for you.
Good luck!
Stanley is offline   Reply With Quote
Old 06-24-2005, 01:33 PM   #9
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
lemon law suck,,,
tsubaru02 is offline   Reply With Quote
Old 06-24-2005, 02:44 PM   #10
Hondaslayer
Brain Stew
Member#: 4562
Good luck!
He has an 03'. He should already have the up-dated (not upgraded) parts.
Old 06-24-2005, 03:08 PM   #11
conker69
Member#: 59692
WRB-Gold
Sorry man but you must do something to have these clutch issues. I don't mean you are responsible for all of it but there must be more.
Old 06-24-2005, 07:00 PM   #12
ronan1975
Member#: 72380
2009 F-150
Green
They CAN"T fix the suspension. They have replace the struts etc....lube everything up...taken it aprt put it back toghether again etc.
I don't have synthetic gear lube in there.
Old 06-24-2005, 07:24 PM   #13
turbokonejo
Member#: 68669
2000 Dodge Durango
My Auto dimming rear view mirror no longer worked @ 22K
turbokonejo is offline   Reply With Quote
Old 06-24-2005, 07:41 PM   #14
Hondaslayer
Brain Stew
Member#: 4562
LCD burnt out. I have seen that a few times.
Did it come with the car? Or was it installed after you took delivery?
Old 06-24-2005, 07:58 PM   #15
dust12
Member#: 13417
I currently have 108k on my wrx and sure it squeaks and rattles a little but its expected. I have had a couple problems with my AC but other then that no major repairs. I had the clutch and the fuel line TSB's done on it. Other then that its a good car. By the way I'm also running a stage 4 (equivilent) setup.
I'm sorry that your car is a piece of junk. I hope you can get it fixed before the warranty is over.
dust12 is offline   Reply With Quote
Old 06-24-2005, 08:15 PM   #16
Soyelflaco
Member#: 46336
2003 WRX - RIP
3 years, 25,000 miles, that's your problem right there.
I had the AC problem and they fixed it the first try.
As far as the suspension noise, DON'T WORRY ABOUT IT, there is nothing wrong with the car.
Soyelflaco is offline   Reply With Quote
Trends I'm beginning to hate in TV commercials. Vostok 7 Off-Topic 39 05-28-2008 03:28 PM
I'm about to hate my car. flyKen74 Mid West Subaru Owners Club Forum -- MWSOC 10 06-03-2006 02:31 PM
I'm beginning to hate my wrx - Lemon Law? ronan1975 Texas Impreza Club Forum -- TXIC 15 06-25-2005 01:57 AM
I'm about to drive my WRX in the snow for the first time Zaffir Mid West Subaru Owners Club Forum -- MWSOC 41 11-26-2004 06:51 PM
I'm off to find my father-in-law a new car beachbum Off-Topic 0 03-05-2004 03:34 PM
Message Board Statistics All times are GMT -4. The time now is 01:56 AM.
