Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 06-24-2005, 05:14 PM   #1
kaisersouse
Member#: 85900
2001 Forester S
Default Are intakes supposed to be this loud?
sounds fine under normal driving, sound slike a damned indy car at WOT or even in the 3500+ RPM range.
i bought a no name intake consiting of an aluminum pipe, 3 vacum hoses and a k&n knockoff (as in imitation) filer. The filter itself is a normal looking cone filter, but the end of it is wide open except for a mesh screen over it. I thought these filters pulled air in from the sides of the filter itself...can i either
a) cover the open end of the filter
b) ditch the knock off and get a k&n or green
also...when i first put it on it tossed a CEL on first start, but after that it went out. There is also what looks like an air-flow sensor that mounted on the front of the original airbox, which i assume is a cali-car thing because ive never seen anything like it before. There was no place to mount it on the intake, but i can always just drill a hole for it. right now its taped to some other wires until i can figure out what to do with it.
car doesnt act funny. accels abit more fierce but the exhaust doesnt reek of unburnt gasoline, it isnt idling odd or acting dumb. is there an easy way to tell if your car is running to rich/lean after one of these?
also, someone suggested wrapping the tube in dynamat to help keep the tube from heating up and therefore causing the air inside to get too hot. how feasable is that?
kaisersouse is offline   Reply With Quote
Old 06-24-2005, 05:36 PM   #2
Jasper
Member#: 80136
2006 Ford F-150
wait, im having a very hard time understanding this....
did you say you taped your MassAirFlow (MAF) sensor to a bunch of wires near the intake? ....and the car runs?
i cant begin to imagine how ridiculously lean you may be running
put the stock airbox back in until you buy a name brand intake with a proper sized housing for the MAF sensor.
Jasper is offline   Reply With Quote
Old 06-24-2005, 05:37 PM   #3
2k2Wagon
Member#: 88776
09 370Z
02 WRX Wagon (PSM)
Uh.. Isn't that your MAF? Seems like it wouldn't run right if that wasn't hooked up.
2k2Wagon is offline   Reply With Quote
Old 06-24-2005, 05:38 PM   #4
bug-eyedwagon86
Member#: 86694
2002 WRX Wagon
Default intake
ditto
bug-eyedwagon86 is offline   Reply With Quote
Old 06-24-2005, 05:39 PM   #5
brex16
Member#: 78703
2004 WRB STi
just ditch the intake for a few reasons:
1) maybe gained 2hp
2) probably messed up your MAF sensor hence the CEL making it rich/lean. (not sure what intakes do for a OB)
3) its a knock off, if your set on the idea that you want a intake, just spend the extra 50-100 and get a name brand one.
4) if you think something is wrong, most likely it is (speaking from personal experience)
5) its just not worth the benefits/risk
goodluck with whatever you decide to do.
brex16 is offline   Reply With Quote
Old 06-24-2005, 05:43 PM   #6
04RCSTI
Member#: 65694
MDC Forever
Black '06 STI
take that off your car asap. before you rreally break something...
04RCSTI is offline   Reply With Quote
Old 06-24-2005, 05:43 PM   #7
kaisersouse
Member#: 85900
2001 Forester S
ill take pics for you guys tonite or something so you can see exactly what im talking about..i dont want to assume things and give you guys the wrong info.
but in all seriousness, it the car runs fine heh. at least....it feels and sounds like its running fine
Old 06-24-2005, 05:44 PM   #8
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
lol, your in safe mode..
that's your maf sensor..
you need it.
throw away the intake.
quit screwing arround with things you don't understand.
DISCOPOPE is offline   Reply With Quote
Old 06-24-2005, 05:45 PM   #9
brex16
Member#: 78703
2004 WRB STi
until KABOOOOM!
Old 06-24-2005, 05:45 PM   #10
brex16
Member#: 78703
2004 WRB STi
seriously tho, take it off you car before you blow something
Old 06-24-2005, 05:48 PM   #11
phlacoe
Member#: 62209
2005 STi
Silver/Silver
How much did you pay for this knock-off? Maybe you should have just got a K&N drop in until you could afford something more expensive.
phlacoe is offline   Reply With Quote
Old 06-24-2005, 05:54 PM   #12
2k2Wagon
Member#: 88776
09 370Z
02 WRX Wagon (PSM)
I like that part the best.
Old 06-24-2005, 08:42 PM   #13
AndyEJ20
Member#: 89337
2004 Subaru WRX STi
WR Blue
I made a mistake on my Intake when I first put it in, ( i know what ur thinking, why would I bother with an Intake??)
But I put the MAF in backwards, boy did I feel like a jackass.
AndyEJ20 is offline   Reply With Quote
Old 06-24-2005, 10:21 PM   #14
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
[GTF]Intakes are for pussies.[/GTF]
Really though, just put the stock airbox back on, before you regret it.
wrxfactor is offline   Reply With Quote
Old 06-24-2005, 11:23 PM   #15
attitude
Member#: 52043
04 sti
i call shenanigans
attitude is offline   Reply With Quote
Old 06-25-2005, 02:22 AM   #16
Lexington
Member#: 50221
I'm on internets
Racin on ur bandwidth!
OMGHi2U
*Hits kaiser with a stick*
NO..... nooo.. dont mess with the MAF! bad.. NoO!
Make sure u didn't blow ur MAF ... if u did, subarus gonna want like 250+ for it more than likely
Lexington is offline   Reply With Quote
Old 06-27-2005, 09:51 AM   #17
kaisersouse
Member#: 85900
2001 Forester S
Sorry to flatten the tires on the bandwagon, buts its a temp sensor, not MAF. I had a real mechanic look at it (yes, one who works on subarus and other imports).
Old 06-27-2005, 10:00 AM   #18
faeker
Member#: 80832
2003 WRX
if the piece was round, it's not a MAF. If the piece was square, shame on you for not plugging it back in.
faeker is offline   Reply With Quote
Old 06-27-2005, 10:11 AM   #19
wrx2.0 555
Member#: 21383
2010 Trek
EX-5
To answer your original question...........
YES..it will be that loud.....I put a Cobb intake on my wifes 2.5 na Baja and at WOT its almost funny..the car sounds like its doing something, but its really not..I chuckle everytime I do it....
wrx2.0 555 is offline   Reply With Quote
Old 06-27-2005, 11:47 AM   #20
subieworx
Member#: 47769
This is the best thread ever!!!!
subieworx is offline   Reply With Quote
Old 06-27-2005, 12:13 PM   #21
ketracel
Member#: 90060
2002 Honda S2000
Berlina Black
I agree with wrx2.0 555. I recently installed a K&N Typhoon Intake... like so many of you were suggesting. The car sounds louder, and the turbo spool is also a LOT louder.
Sounds very nice, actually... I love the sound of the turbo spooling...
ketracel is offline   Reply With Quote
Old 06-27-2005, 12:24 PM   #22
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
I REALLY love the sound of the turbo spooling in the WRONG FORUM. Kinda like nails on a chalkboard. This is about intakes for an N/A vehicle. BIG difference.
Jared
gtwagon941 is offline   Reply With Quote
Old 06-27-2005, 02:09 PM   #23
kaisersouse
Member#: 85900
2001 Forester S
it was round and looked like a temp probe. i mentioned MAF because i had seen people talking about it in earlier threads. I assumed after the install that it WASNT the MAF since the car started and ran (and has since continued to run) perfectly fine.
I'm sure the accel is pure placebo, and its not like it was a COLD air intake (that i wouldnt bother doing unless i had an engine worth doing it to).
Its loud, its pretty, its cheap...whatever car's doing fine, im doing fine and the mechanic said ill continue to be fine so i shall worry no longer.
Old 06-27-2005, 02:25 PM   #24
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Great that it is not the MAF. But, get a new filter. If the end of it is wide open except for a mesh screen you are not filtering any air. That mesh is the only thing between dust and water and crap and you internals. That is also why it is so loud. Get a filter that covers the end of the tube completely. Also watch out for water and rain until you get that covered.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 06-27-2005, 02:58 PM   #25
kaisersouse
Member#: 85900
2001 Forester S
Peace,
Greg
for now i got a 5" heavy-duty rubber cap (used for plumbing but the heat rating is high) over the end of the imitation filter until i get a REAL filter.
Thanks to all who replied in a serious/non-judgmental way
is my power steering pump supposed to be this loud? XanRules Service & Maintenance 9 04-18-2010 02:45 AM
Are resumes getting longer? I thought they are only supposed to be 1 page? Cjchaps Off-Topic 45 06-30-2005 02:49 PM
are brand new wiper blades suppose to be this dirty? mr_yellow General Community 12 09-21-2003 11:29 PM
i'm in a mood, you pplz is screwed. Are humans supposed to be Monogamous ? Keith Off-Topic 20 04-02-2003 04:39 AM
Are the spherical bearings on my Perrin end links supposed to be this stiff? dsc Brakes, Steering & Suspension 1 02-21-2003 01:41 AM
