Old 06-24-2005, 05:11 PM   #1
kicking1012003
Member#: 73435
2004 Subaru WRX STi
WR Blue two tone w/ CF
Default Gauges
I am recently in the market for a boost gauge and a 'pod' of sorts to hold the gauge. I am looking for something that is not crap, still somewhat respected by people and fairly cheap. If anyone out there has any ideas or info for me please help.
kicking1012003 is offline   Reply With Quote
Old 06-24-2005, 07:33 PM   #2
justbcuz
Member#: 81699
2003 wrx
black
Cheap and not crap are a contradiction in terms.
Look at delphi gauges.
justbcuz is offline   Reply With Quote
Old 06-24-2005, 07:39 PM   #3
AndyEJ20
Member#: 89337
2004 Subaru WRX STi
WR Blue
If I were to get ANY kind of gauges, I would get an Engine Temp Gauge, and if you already have one(i don't) replace the Factory boost gauge, as there are to be a little inacurate.
AndyEJ20 is offline   Reply With Quote
Old 06-24-2005, 07:51 PM   #4
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Defi is the only way to go in my book since they match perfectly.
blinguskahn is offline   Reply With Quote
Old 06-24-2005, 08:09 PM   #5
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Defi is the way to go, their center pod that replaces the stock clock is wonderful. or the Perrin pod that goes on top of the steering wheel.
If I had to recommend two gauges that EVERYbody should have, it's the EGT gauge and boost gauge (that can read vacuum and in psi)
For a third gauge I'd suggest oil pressure gauge, anything beyond that is up to you.
eltrouble is offline   Reply With Quote
Old 06-24-2005, 08:16 PM   #6
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
STi Genome Gauges by Defi. Just cuz they have Pink.
Originally Posted by JUSTBCUZ
delphi gauges
W T F kind of brand is that?
J-Rex2004 is offline   Reply With Quote
Old 06-26-2005, 03:15 PM   #7
kicking1012003
Member#: 73435
2004 Subaru WRX STi
Thanks for everyones imput but as to this comment I am assuming that you mean get a boost gauge first, correct? Right now i do not have any types of gauges so I'm assuming you mean boost then ETG. By-the-way why should i get ETG? Just to keep down on the overheating and what-not? Thanks again
Old 06-26-2005, 08:23 PM   #8
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
yes, boost gauge first, the factory one is just...not good.
And I assume you mean EGT gauge. Exhaust Gas Temperature. It lets you know if you're car is running lean or rich. The WRX typically runs slightly rich than stoichio, but the EGT lets you know if there are any issues with how its performing.
Old 06-27-2005, 02:03 AM   #9
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
I installed the dual pod gauge housing that replaces the dash cluster housing. It fit very well, looks stock and holds two gauges front and center for easy reading. The gauges had red "light covers" that make it match the STI gauges pretty closely. No other gauge info is blocked by it's location. I'll have to look to remember the brand of gauges; boost/vacuum and oil temp with sensor bolted into a main oil gallery. Any overheating problems will show up in the oil such as too high egt. Never liked the look of those egt gauges with the bar. I like analog. hwy61
bars.
hwy61 is offline   Reply With Quote
Old 06-29-2005, 06:58 PM   #10
justbcuz
Member#: 81699
2003 wrx
black
Haha, I don't know what I was smoking... I meant defi.
Old 06-29-2005, 11:13 PM   #11
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Originally Posted by kicking1012003
I am recently in the market for a boost gauge and a 'pod' of sorts to hold the gauge. ...and fairly cheap.
For a my2002...
(1) Get an Omori "WRX-Look" mechanical boost gauge for probably US$120(?) + a center-mount pod (US$30?), or..
(2) Get a mechanical boost gauge, like this one below (AutoGage) for about US$28, pry it open, repaint the needle ( < US$4 ), trim an opening in your oem bezel shroud, fabricate a pod made of sheet metal ( < US$5), and install it there.
http://forums.nasioc.com/forums/showthread.php?t=705607
(ignore the caption on the pic below)
satrya is offline   Reply With Quote
FS : 2005 Stock exhaust, shift knob SUPER CHEAP infinite012 MAIC Private Classifieds 26 07-09-2010 08:21 AM
52mm STRI gauges- price drop TheNailman NESIC Private Classifieds 82 06-24-2010 06:00 AM
52mm STRI gauges- Price Drop TheNailman Exterior/Styling 111 06-24-2010 05:58 AM
FS : Meth / water injection kit NEW! defi gauges boost, egt JT's06sti Engine/Power/Exhaust 7 06-17-2010 11:45 PM
Water Temp STRI gauge malfunction emsmap Electrical & Lighting 5 06-08-2010 11:09 AM
