Old 06-24-2005, 06:32 PM   #1
Dawson
Member#: 71909
Default Ground problem
I have a 2001 impreza rs. and i have a ground problem. i have no lo-beams and i need to know where my body grounds are and engine grounds are if anyone could help me out it would be a lot of help. thanks.
dawson
Dawson is offline   Reply With Quote
Old 06-24-2005, 06:48 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your non-functional low beams have nothing to do with a main ground issue. The Subaru lights are a common positive, switched ground system. There is no direct ground for the low or high beams, they are grounded through the headlight switch depending on which beam you select.
And your problem may be very simple, such as both low beam filaments being blown. Have you checked them?
Sound coming from grill, alarm grounding problem? sampson Electrical & Lighting 1 01-06-2005 02:45 PM
@#&@, more grounding problems. wrxinmn Car Audio, Video & Security 9 11-01-2004 11:39 PM
HID kit in EDM Projectors grounding problem? 9krpm Electrical & Lighting 3 10-08-2004 06:43 PM
AC or grounding problem tad Legacy Forum 0 08-21-2004 07:23 PM
Another grounding problem and Alpine RSser Car Audio, Video & Security 10 09-17-2001 01:30 AM
