Old 06-24-2005, 10:13 PM   #1
rice wrx
Member#: 89698
Default Ignition cut under load/boost?
just the other day, the car started cutting out when under load and boost around 4000 rpms ... a/f ratio goes rich (per utec) so I am guessing an ignition problem or a/f sensor problem. Anyone else eperienced anything like this ... I am gonna pull the plugs out tomorrow.
Mods: STi pinks, vf34, utec, full catless exhaust/headers, shorty intake, fuel pump
thanks
(it does this on all maps)
rice wrx is offline   Reply With Quote
Old 06-25-2005, 07:25 AM   #2
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
What is your voltage at WOT? Check grounds on motor/tranny. Fuel or ignition issues I'd guess.
turbo2ner is offline   Reply With Quote
Old 06-25-2005, 10:12 PM   #3
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
i had a similar problem. i thought it was b/c i wasnt getting enough fuel, (went from 6psi to 8.5 psi) so im just gonna upgrade my injectors. hopefully that will work. if u figure something out let me know, to the best of my knowledge there are no ignition upgrades for my gc.
farrell is offline   Reply With Quote
Under boost? or Under loaded? AlaskanProtege Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-22-2009 10:20 AM
Power cuts on/off under *LIGHT* boost ChuChi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-19-2007 04:51 PM
Ignition cut under load/boost rice wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-24-2005 10:17 PM
Car cutting out+ dying under load?!?!? fuel pump? HorsepowerFreaks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-11-2004 01:42 PM
Help- fuel cut under boost when turning wop Normally Aspirated with bolt-on Forced Induction Powertrain 14 04-10-2002 11:34 AM
