Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Notices
Old 06-25-2005, 04:40 AM   #1
aznatama
Member#: 60316
2004 STi
Default Hydra EMS question
is the hydra EMS avaliable w/ a base map already loaded? or will I have to tune/upload a new map completely from scratch??
sorry if this was already answered as I couldn't find the answer anywhere...
aznatama is offline   Reply With Quote
Old 06-25-2005, 06:37 AM   #2
erggy
Member#: 51202
yes it comes with base maps
erggy is offline   Reply With Quote
Old 06-26-2005, 03:27 PM   #3
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Definately has base maps.
offset
offset is offline   Reply With Quote
Old 06-27-2005, 03:34 AM   #4
aznatama
Member#: 60316
2004 STi
So next question that I can't seem to get answered on any of the Hydra EMS sites...
If I just went and bought a Hydra EMS w/ the wideband O2... can I just plug it in and be able to drive my car for a while (at least til I can get it to a tuner sometime down the road)? or will it run like crap unless I tune it?
becasue I'm busy w/ work on the weekdays, I want to install it one weekend, and then take it to the shop on another weekend. will I be alright this way?
BTW, this is my planned upgrade path in terms of power...
1. Hydra EMS
2. injectors (800cc?)
3. downpipe? (are the stock ones terribly inefficient? I'd like to keep the car as stealth as possible)
Old 06-27-2005, 05:41 AM   #5
traction issuez
Member#: 86559
2005 RS Wagon
sorry for robbin the thread, but anyone know how to contact phil? from hydra?
traction issuez is offline   Reply With Quote
Old 06-27-2005, 09:32 AM   #6
gt35sti
Member#: 70831
2004 STI Blue
w/Hydra
Heres his shop # from the web site 240-246-0302
gt35sti is offline   Reply With Quote
Old 06-27-2005, 10:50 AM   #7
erggy
Member#: 51202
depends on the map that u get.. for base maps u should be able to drive around with not much load. It should be relatively safe (low ign, rich fuel).
Can I ask why change injectors to 800cc w/o turbo mods? or u've got a gigantic turbo already?
Old 06-27-2005, 10:56 AM   #8
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
The best advice is to just call Phil at the number posted. You will be able to get all your answers much more quickly that way. And he will probably even give you some answers to questions you didn't realize to ask yet too.
offset
Old 06-27-2005, 01:24 PM   #9
aznatama
Member#: 60316
2004 STi
I didn't want to bother Phil w/o exhausting my resources on the forums and searching about it first. I'm sure Phil gets a lot of calls with questions that could've easily been asnwered by a quick search or question here on the forums... just being courteous on my part.
As for the injectors, I read on the element tuning site that their injectors were running static at 5500rpm... or was that for the WRX?? well, injectors won't be done unless the logs show that the stock ones are insufficient. I'd like to keep injectors at 80% load or below. I do plan to increase boost a bit, but only on track days, and I don't think I'll ever upgrade the stock turbo until it's either in need of replacement or when I'm done w/ all my suspension and drivetrain upgrades.
Old 06-27-2005, 04:17 PM   #10
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
We have great base maps for the STI using stock injectors with a TBE and for the same with 800 cc injectors. Our maps go all the way up to 65 lbs compressor turbochargers.
For your current modifications and as long as you follow an Element Tuning recommended modification path, we have maps that you'll be able to drive around without issue.
In the warmer months you may not max out the injectors but I guarantee they will be in the 90% range if you run around 11.0 AFR.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-27-2005, 06:08 PM   #11
aznatama
Member#: 60316
2004 STi
Phil,
Thanks for your response on the thread earlier. just wondering, if I wanted to get the Hydra w/ a wideband O2, do I just plug it into the stock O2 location? or will I need a separate bung welded somewhere?
Also, how much would it be to purchase everything I need for the install on my 04 STi?
Old 06-28-2005, 08:21 AM   #12
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
It will come to just under $2k shipped. And yes the stock O2 location will be just fine for the new wideband.
offset
Old 06-28-2005, 01:20 PM   #13
lowturboboost
Member#: 61424
There's no need to install and use the wideband until ready to tune the car. It will also save it's life a bit. Unless the base map you receive is setup to use wideband, you will have to use it, unless you know how to work around in the Hydra and disable the wideband usage and AFR Target Table or ask Phil for support on how to do it.
If you are running stock turbo, there is no need for 800cc injectors. The most recommended path would be to use a TBE, increase a tad of boost and the Hydra.
Then you can do, fuel system, turbo, more boost and other routes.
lowturboboost is offline   Reply With Quote
2004 Sti Hydra EMS II 2.6 ECU SOLD tolishel Engine/Power/Exhaust 8 07-07-2010 04:50 PM
question hydra ems davidsti1 Other Engine Management 3 06-22-2009 10:43 AM
AEM EMS -Trade- for Hydra EMS, 02-05 wrx AwdBoostCreep Engine/Power/Exhaust 2 05-22-2009 11:14 AM
Hydra EMS OBDII Question Buggn' Out Other Engine Management 20 11-30-2008 11:40 PM
Hydra EMS...... carguyx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-22-2004 12:35 PM
