Old 06-25-2005, 02:08 PM   #1
Jonathan_Yi
Member#: 2030
2000 2.5RS coupe
Blue Ridge Pearl
Default Problem after ECU reset
If anyone has a clue it'd be greatly appreciated.
I needed to get my car inspected but I had an CEL (I'm pretty sure it was the cat inefficiency code) so I disconnected the - terminal on the battery and pulled the E/G Ign fuse and stepped on the brake for a bit.
After I reconnected the battery I started her up and it was idling VERY rough to the point the car was shaking.
So I turned the car off and turned it back on and now the car will not idle at all, it just dies. If I give it gas while starting it still revs rough and I smell gasoline.
Any clues?
Thanks
Jonathan_Yi is offline   Reply With Quote
Old 06-25-2005, 02:28 PM   #2
ScoobyDoobieBlue
Member#: 71509
2000 Subaru 2.5RS
BRP
Did you put the fuse back in?
ScoobyDoobieBlue is offline   Reply With Quote
Old 06-25-2005, 02:32 PM   #3
Jonathan_Yi
Member#: 2030
2000 2.5RS coupe
Blue Ridge Pearl
Yes. Just for good measure I tried to start the car and it won't turn over, so the fuse is still good.
EDIT: I meant to say that I tried to start the car w/o that fuse and it wouldn't turn.
Old 06-25-2005, 05:06 PM   #4
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
fault inticates that you maf is malfunctioning.
why after a reset thought...
Sober_One is offline   Reply With Quote
Old 06-25-2005, 06:06 PM   #5
Jonathan_Yi
Member#: 2030
2000 2.5RS coupe
Blue Ridge Pearl
MY00 have a MAP, not a MAF.
I checked out the spark plugs and I noticed oil after I took out one of the spark plugs.
EDIT: Forgot to add that of course Murphy's Law dictates that after changing all the spark plugs JUST IN CASE, the lead(? the metal contact part) inside the wire came out and of course the dealer is closed.
07 STI STAGE II(PDX Maps) - Stutter Problem after ECU Reset subbie03 AccessPort 3 02-11-2009 03:10 AM
problem after i reset my ecu burtonboy759 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-02-2008 08:01 PM
Stock Alarm problem after ECU reset Longitude Car Audio, Video & Security 6 01-10-2001 12:20 AM
Problems after ECU reset Gorio Normally Aspirated Powertrain 10 12-05-2000 06:49 PM
Idle problem after ECU reset Spectre23 Technical Forum Archive 1 05-19-2000 12:42 AM
