Old 06-25-2005, 06:47 PM   #1
shemoves
Member#: 80663
2005 STi
Default Is it possible to mute the Defi BF's
It is it possible to mute the Defi BF's audible alarm? (lost my manual) If so, how?
shemoves is offline   Reply With Quote
Old 06-25-2005, 07:18 PM   #2
shemoves
Member#: 80663
2005 STi
even just a yes or no to get me started would be fine
Old 06-27-2005, 11:07 AM   #3
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I don't think you can. The only way I know you can avoid having the buzzer go off is by setting the warning point high. Not the greatest idea though, as the red lights will not turn on either.
I think the only way to get rid of the buzzing is to find where the speaker is in the control unit and disconnect it. I have never taken mine apart, so I can't speak from experience.
I'll double check the manual and see if I can find anything.
coyote73176 is offline   Reply With Quote
Old 06-27-2005, 11:29 AM   #4
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I just double checked the manual and it makes no mention of being able to turn off the buzzer for the warning. I am sure there is probably a way, but its not a built in function in the Defi-Link meter.
Old 06-27-2005, 11:49 AM   #5
ChrisL2
Member#: 1444
Why do you need to mute the alarm?
It should only be going off if you exceed the warning point.
Cover the speaker with something. Mine is rather quiet for some reason. It used to be loud in my other car.
ChrisL2 is offline   Reply With Quote
Old 06-27-2005, 11:57 AM   #6
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
With the temperature warning it will not go off until the temp drops below the warning point. This is the only time I have found it annoying (not sure why the original thread starter wants to turn it off).
I could see it it buzzed for a few seconds to let you know, if your not paying attention to the light on the gauge, but for those people who set the warning points well below the threshold it can get annoying.
I know with my oil temp gauge, I had it set to 100C because during normal driving it stays pretty steady at 90C. Now that we've been in the midst of pretty hot temps here in NY, during highway driving it stays closer to 100-105C. I just set the warning point higher (110C) and check the gauge more often as I am driving.
Old 06-27-2005, 01:47 PM   #7
shemoves
Member#: 80663
2005 STi
Thanks for the responses. I wanted to turn it off because one of the guages is linked to the chain but the actual sensor is not installed yet...so it basically always reads 0 (the audible alarm turns off for this guage when I start the car though.) Also, when I am just sitting there, lets say listening to the radio with the engine off, the oil press goes off...I guess I could just unplug the unit if I know I am gonna be sitting for a while.
Old 06-27-2005, 11:34 PM   #8
ChrisL2
Member#: 1444
You need to rewire the defi link controller to stop the warning buzzer when the key is in the ACC position. I tapped into the far left bottom fuse for the IGNITION wire. Gauges only power up when the key is turned to ignition.
I can post a tomorrow if you need one.
Old 06-27-2005, 11:49 PM   #9
SSTINGER77
Member#: 45635
02 WRX Wagon
its simple.... if you want to shut up the gauges warning, you just hit "play" and then hit either rewind or FF... then it will pause the "play" and the noise will go away (assuming your talking about when your engine isn't on and you want to listen to music etc.)... ez fix, unless u really wanna go through all the trouble of rewiring...
SSTINGER77 is offline   Reply With Quote
Is it possible to bring the 4pots close to the stopping power of Brembos? Hyper Brakes, Steering & Suspension 2 10-31-2006 03:20 AM
is it possible to get the WRX letters on to the IC? Carbon888 Interior & Exterior Modification 41 04-05-2005 02:07 PM
How is it possible to mount the car body six inches the left of the frame? scaryfastskier Off-Topic 16 10-26-2004 08:30 PM
Is it possible to get the benefits of a lighter crank pulley without the negatives? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 07-02-2003 01:44 AM
Is it possible to remove the turn signal cone form the headlights? Davenow Interior & Exterior Modification 4 09-05-2002 01:18 PM
