Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-25-2005, 08:52 PM   #1
Dionysos911
Member#: 72943
2005 WRX Sdn
CGM
Default Boost guage indicate gas mileage?
N00b here.. I was wondering if the boost guage can be used to indicate what kind of gas mileage you're getting. On the freeway I notice that when I set the cruise control going about 70 that more boost is used in 5th gear than in 4th. Do I get better mileage in 4th gear?
Dionysos911 is offline   Reply With Quote
Old 06-25-2005, 09:28 PM   #2
Remnex
Member#: 83790
Nope my good sir. You will boost lower in 1st gear than 2nd and so on. More boost is used to propel the car faster in higher gears.
For example. I boost 11psi in first, 13.2-13.5 in second, 14 psi in third, 15 psi in fourth and fifth.
I am Cobb Stage 1 by the way.
Remnex is offline   Reply With Quote
Old 06-26-2005, 12:39 AM   #3
23b_Rex
Member#: 79394
02 gda
wrb
^ yep
just keep it in the highest gear possible without bogging the car and you'll get the best possible gas mileage
23b_Rex is offline   Reply With Quote
Old 06-26-2005, 01:02 PM   #4
JeffrWRX
Member#: 48589
2016 WRX 6mt
CWP
Since I've installed my boost gauge I've gotten better MPG...I try and keep it at 0 or in vacuum as much as I can. IIRC keeping it in vacuum will net better gas mileage.
-Jeff
JeffrWRX is online now   Reply With Quote
Old 06-26-2005, 02:11 PM   #5
makanai
Member#: 65277
2004 WRX Wagon
Platinum Silver
Keeping it in vacuum means you're not gassing the car as much. I don't think the turbo being active actually reduces gas mileage much, if at all, but having it in positive boost means you're asking the car to do more (i.e., you're getting on the accelerator, and the car is keeping up to your request by going into boost).
Like any car, asking for rapid acceleration means getting worse mileage. The boost guage is a good way to eyeball this because it gives you a direct visual cue as to what you're currently "asking" your car to do.
makanai is offline   Reply With Quote
Ways to boost gas mileage? mstein Normally Aspirated Powertrain 21 11-02-2006 10:26 AM
Gas Mileage under boost hoku123 Newbies & FAQs 18 07-09-2005 10:16 PM
lower boost= Better gas mileage? jdmhebek9 STi Forum Archive 12 08-27-2003 08:07 PM
Reason to run less than stock boost? Gas mileage for highway/grocery-getting, etc? JSiwek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-24-2003 04:58 PM
gas mileage, boost controllers scott_gunn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-26-2001 07:32 PM
