Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-26-2005, 12:11 AM   #1
Iceman12321
Member#: 71034
2001 Outback Ltd.
Sedan - White
Default Air Box
I've done some research on CAI, and i have a question. There are intakes that work with the stock air box, whereas there are others that do not. Are there any advantages or disadvantages with having the intake work with the stock airbox? Are there more power gains when using the stock airbox or without it?
thanks in advance
Iceman12321 is offline   Reply With Quote
Old 06-26-2005, 12:26 AM   #2
Handsdown
Member#: 29355
you tend to retain more mid-range torque with it, but lose some peak HP high in the revs.
it's generally not worth getting rid of on the 99+ newer 2.5L's.
Handsdown is offline   Reply With Quote
Old 06-26-2005, 08:29 AM   #3
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
^^^ none of that has been proven anywhere. It's just speculation. Show me a dyno that proves an intake that uses the stock box makes more mid range torque than one that doesn't. If you're looking for an intake I would recomend either Injen or Cobb. People have good things to say about both.
X4 SRT is offline   Reply With Quote
Old 06-26-2005, 07:24 PM   #4
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I had a GanzFlow CAI that retained the stock airbox, and it didn't really do much. My A/F ratios didn't change, so it wasn't really pulling much more air into the engine. I recently purchased a short-ram Weapon R Secret Weapon, and when that went on, my A/F leaned out, indicating an increase in the amount of air entering the engine. I have not noticed any loss of torque anywhere in the rev range, abut the power difference is definitely noticable. Also, I have run some tests on air temps under the hood and in the fender, and have found that the only time a fender-fed CAI will help is in stop and go traffic, when underhood temps build up. Once you get moving, though, temps drop quickly. Parked, there was a 20F+ degree difference between underhood and in fender temps, but during normal driving, the difference was marginal, at best, and about 8f degrees. And I'm just talking about cruising around town. Also, once I removed the vent backing plate on the side with the intake, the temps tend to build a little slower, and drop back off faster. In other words, there really isn't much of a gain to be had with a CAI over a short-ram.
If you want the numbers:
http://www.rs25.com/forums/showthread.php?t=31368
HondaH8er is offline   Reply With Quote
Old 06-26-2005, 07:28 PM   #5
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
is a short ram just the first half of the CAI? (ie no filter and the air does'n come from the fender?)
hendo2.5 is offline   Reply With Quote
Old 06-27-2005, 12:40 AM   #6
EJLsubie
Member#: 59407
2004 Legacy 35th Ann
Mystic Blue
EJLsubie is offline   Reply With Quote
Old 06-27-2005, 05:37 PM   #7
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Kind of. A short-ram would be an intake that doesn't reach to the fender, so it will look like half of the Cobb, but it will have a filter on the end.
Old 06-27-2005, 06:07 PM   #8
Handsdown
Member#: 29355
short ram means that the intake piping is as short as possible so that air doesn't have too much surface area slowing it down on the way to the engine.
it really isn't a ram air intake unless you place the filter at a point that will cause positive pressure at speed... which is hard to do and is measured with a vacuum gauge. a ram air intake doesn't work too well for enclosed engine bays, so if you do that make sure you have lots of vents in your hood.
Old 06-27-2005, 08:40 PM   #9
Iceman12321
Member#: 71034
2001 Outback Ltd.
Sedan - White
so a car without any vents/scoops wouldnt work well with a ram intake?
Old 06-27-2005, 10:22 PM   #10
Handsdown
Member#: 29355
it's not a true ram intake if there are no vents leading to a positive pressure intake.
but in general short ram intakes don't make as much power, no.
Stock Air box without Ram Air Scoop? subaru_steve Newbies & FAQs 2 06-02-2010 08:48 PM
Sti air box / snorkkus vs. WRX air box / snorkus neonglh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-30-2007 12:26 PM
WTB: 00-01 RS or 00-02 Forester stock air cleaner / air box / air intake tubes JapCarRealGood SWIC Private Classifieds 2 12-30-2006 02:18 PM
'99 RS 2.5 Fender filter box and Engine air box - both have filters in them. cjfike Normally Aspirated Powertrain 5 11-02-2005 11:55 AM
ARC air box brand new in box $350 wrx/sti jdmej20 Private 'For Sale' Classifieds 0 03-17-2005 06:28 PM
