Notices
Old 06-25-2005, 11:30 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Exclamation Engine Management FAQ: Read if you are thinking of buying one!
Why do I need engine management? Consider your stock engine management for just a moment. Your stock engine control unit (ECU) is a very complex piece of circuitry that calculates hundreds of variables every second. All of these variables rely on inputs within a + or – range. When you modify your vehicle, these values change. As long as the changes are within the values the ECU expects to receive, your engine runs fine. Once the values are exceeded, the ECU is programmed to compensate to return the values to normal levels.
This is a layman’s explanation of how your stock ECU can actually work against you when modifying your vehicle. This also explains why modifications can feel great once they are bolted on but the butt dyno results seem to fade over time. This is due to ECU compensation.
What is the first step in finding what engine management I need? Finding a tuner. The Tuner FAQ will help with the general rules of finding a good tuner. Remember, it's always better to have a custom tune vs. a plug and play or "staged" map. Always defer to the tuner's advice as to what to choose as ultimately he will be the one to provide custom support. Discuss your goals and budget and your tuner should set you on the right path. If you are a "plug and play" kind of person, review the options below and decide for yourself along with input from locals in your regional forum and the car parts review forum.
What will engine management do for me? Generally speaking, engine management optimizes several engine functions to create more horsepower and efficiency. The stock ECU is designed to ensure your car runs fine and monitors the engine’s output parameters. Utilizing an aftermarket engine management solution takes this to the next level.
Often times, car manufacturers will program the stock ECU with a known amount of “play”. This amount of play allows the manufacturer an extra level of safety and/or the ability to utilize this at a later date so they can have an increase in HP in later years. An example of this is where a 2001 car has 200HP and a 2002 car has 215HP. Some manufacturers couple this with additional parts to get increased HP levels, but this should give you some idea of the concept. From a marketing and sales aspect, this ensures that the public will continually be interested in the new year models, even if the body style does not change. While this FAQ is not about the science and art of auto sales, this may give you an insight as to why the stock ECU is not 100% perfectly tuned from the factory.
What are the least talked about benefits of engine management? Engine management solutions to one degree or another can reduce or eliminate black tailpipes, improve driveability throughout the powerband, eliminate the open/closed loop delay in 04+ Subarus, and increase MPG.
What Subarus NEED engine management? While every Subaru will benefit from engine management, the 04+ turbo models (except STI) "require" it. The reason for this is the EPA mandated greater restrictions on ECUs for 2004+ and allow manufacturers to exclude one model. Subaru chose the STI as the exclusion, so the restrictions are not on the STI. The restrictions have to do with the open and closed loop fueling. To put the restrictions in a nutshell without being technical, there is a delay between open and closed loop fueling that can allow your 04+ Subaru to run lean during this crossover point in how your car gets fuel. Lean is dangerous as it produces detonation which is the #1 factor is blown pistons. In stock configuration, 04+ turbo models are fine, but modifications such as exhaust work or higher really necessitate the use of engine management as those mods cause the fueling issue to rear it's head. Yes, you can run certain mods for a short time until you get engine management, but you should never kid yourself on 04+ turbo models that bolt on modifications are fine without engine management.
What about manual/electronic boost controllers or air fuel controllers?
A manual/electronic boost controller or air fuel controller really isn't engine management. MBCs are fine when used correctly on 02/03 WRX and 04+ STI by a judicious user. The issue gets further clouded on 04+ turbo models less STI, due to the open/closed loop delay. One can lump in the mix air/fuel controllers as well for the same reason. Usually those two devices are used by either cheap skates, n00bs, or advanced users who combine them with other forms of real engine management.
What types of engine management solutions are available? They fall into one of these general categories:
a. Reflashed ECU
b. Custom Tuned ECU
c. Piggyback Engine Management
d. Stand Alone Engine Management
e. Open Source Engine Management
Reflashed off the shelf ECU: This is your stock ECU that has had the programming modified. This form of engine management is best suited for people who:
a. Have a “set it and forget it” attitude towards engine management
b. Live in remote areas and do not have easy access to a tuner
c. Do not want to learn or are uneasy doing their own tuning
d. Want to modify their vehicle to a certain level and quit or add parts very infrequently
It is important to note that while reflashed ECUs are considered a static engine management option, they can be custom tuned by the end user by utilizing additional add-ons from the manufacturer or via a custom tuned reflash by an authorized tuner.
In addition, also consider that EcuTek tuners might have reflashes for your exact equipment set-up based on their prior custom tunes. This means that someone who has a full TBE might find the Cobb AccessPort a better plug and play solution, while someone with a full TBE, uppipe, headers, & a lightweight pulley may find an EcuTek reflash a better plug and play solution if they can find an EcuTek tuner with that exact map.
Recently for AccessPORT users, "custom maps" have become vogue. These come in the form of more specific maps for specific mods. Let say you have a stage 2 car with headers, TGV deletes, and a pulley. You email this information to a tuner and they will create a custom map for those mods to use. Some will send you a map and logging software, you load the map and data log, then the tuner sends you a final customized tune. While not as perfect as an in-person/on-dyno custom tune, it's a great resource for those in areas without tuners. Companies that do this are PDX Tuning, Perrin, and Clark Turner.
Examples of reflashed ECUs are the Cobb AccessPort and EcuTek (including Prodrive’s PPP & Vishnu’s reflash).
Reflashed custom tuned ECU: This is the next evolution to a reflashed ECU. This allows either the end user or a professional tuner to custom tune your vehicle to your specific modifications, wants and desires, type of gasoline used, and geographic area. This form of engine management is best suited for people who:
a. Will probably modify their vehicle frequently and require additional tuning
b. People with the ability to do their own tuning
c. People that live close to a tuner
d. People that want to get the maximum power and safety out of their car
Examples of Custom Tuned ECUs are Cobb Tuning’s StreetTUNER for end user tuning, Cobb Tuning’s ProTuner for professional custom tunes, EcuTek custom tune via an EcuTek tuner, and EcuTek's DeltaDash Live User Tuning, an end user tuning solution.
Piggyback Engine Management: This is an engine management option that works in conjunction with your stock ECU. Depending on the manufacturer, this solution works by the piggyback unit controlling some engine management functions and the stock ECU controlling others. This form of engine management is best suited for people who:
It is important to mention that most piggyback units come with base maps. These base maps work very similar in function to a reflashed ECU whereas you can run the base map and be 100% fine, or when the day comes for someone to tune their own car or have it professionally tuned, they may do so.
Examples of Piggyback Engine Management are Unichip, Xede, UTEC, and others.
Stand Alone Engine Management: This is an engine management solution that totally replaces the stock ECU and controls 100% of the engine’s functions. This form of engine management is best suited for people who:
This form of engine management is generally reserved for more advanced users and people going for really high levels of performance.
It is important to mention that most stand alone systems do come with base maps. Unlike the base maps that come on reflashed ECUs, these base maps are meant for your vehicle to run for a short period of time and are not meant to be used as a permanent solution as is the case with the other base maps as described above. Consider these base maps as merely as short term option until end user or a professional tuning.
Examples of stand alone engine management are MoTeC, Hydra, AEM, and others.
Open Source Engine Management: This can be the cheapest source of engine management available. In essence, you use a laptop, software, and a cable to reflash your stock ECU. Can be used to flash "staged maps" as a set it and forget it option or as a dynamic tuning tool either through tuners or by the end user. This form of engine management is best suited for people who:
Group 1:
A. Already have a good degree of tuning knowledge and understand the logic of the factory ECU (or have a strong desire to learn both).
B. Want to constantly tweak and experiment with their own tune. They actually enjoy the process.
C. May be changing/upgrading mods frequently.
Group 2:
A. Looking to get a custom tune from a professional but cannot afford or do not want to spend the money on license fees and/or hardware costs required of Cobb, Ecutek, etc. That is, they want their car to have a custom tune from a pro at the least cost. More and more professional shops are offering open source tunes and they can be just as capable as tunes from the commercial software.
B. Want an inexpensive (ex. XPT) or free (created by another user) OTS map. Might not go with EM otherwise because they feel it is too expensive. They are willing to learn the basics of logging with RomRaider to make sure the tune doesn't have any issues with their car.
Those people where Open Source Engine Management would be a BAD choice (assuming they are doing it themselves and not a professional tuner):
1. Want the easiest to use, troubleshoot, and closest thing to "set and forget" EM solution.
2. Are computer illiterate.
Examples of Open Source Engine Management are RomRaider, formerly known as Enginuity, EcuFlash, and others.
Can the dealer detect my reflashed ECU (AccessPort/EcuTek/Open Source)?
YES the checksum of the ECU changes.
YES the dealer can easily read the checksum.
NO the dealer has nothing to compare the checksum against there are many revisions of the WRX ecu they all have different checksums. If the dealer had someway of putting this checksum into a database he COULD verify that the code had been modified but at this time he doesn't.
The 05+ ECU and some of the 04s have the VIN in the ECU code. The current versions of reflashed ECUs only change the tables so the VIN will report when queried.
Bottom line: If you don't want modifications to be detected, don't modify the car.
What are some specific types of engine management While this FAQ does not go into specifics for every type of engine management, this thread covers many types. This link offers several comparisons of different system features as well. There are some not covered in these threads though and may be considered as well.
Generally speaking, what engine management option will give me the most power? Custom tuned engine management solutions will always give you more power. Every off the shelf engine management solution has a built in safety factor. This depends on the manufacturer. This is because their “Stage 1” or “VF-30” map has to safely make power for someone living in Phoenix’s heat and 91 octane, to Denver’s high altitude, to Boston’s cold and 93 octane. The gasoline and geographic variances can leave horsepower on the table.
More specifically, what engine management option will give me the most power? This is one question without a correct answer. Let’s say that you research a very comprehensive stand alone engine management system such as a MoTeC unit and decide that it’s the “best” for your car. At the end of the day, it’s about what the tuner is most comfortable with. Some tuners may be able to extract better results from a “lesser” system simply because they understand the interface better.
For someone interested in tuning their own vehicle, they should match their tuning skills with an engine management solution that they are able to understand and use correctly. For someone interested in professional tuning, they should consult with their tuner for their recommendations. Both of these actions will ensure a good tune with a minimum amount of rework, guessing, and trial and error. While most tuners are capable of learning new or more advanced engine management systems, consider the benefits of an “older/worse system” your tuner is familiar with vs. your tuner learning a “newer/better system” at $200/hour plus possible dyno time.
I have a reflashed ECU and am not seeing their advertised HP, why? First off, have you met their criteria EXACTLY? The #1 cause of low HP with reflashed ECU owners is their lack of meeting the manufacturer’s requirements. If they require a full turbo back exhaust and you only have a downpipe and a cat back exhaust, 100% of the blame is on the end user. As well, if they require a full exhaust and you have a full exhaust, uppipe, headers, and a bigger top mount intercooler, this can cause problems as well.
Also realize that HP figures vary. You cannot compare (for example) a manufacturer’s Mustang Dyno HP figures to your local DynoJet HP figures. Even comparing identical dynos to each other is futile as dyno software set-up, altitude, temperature, humidity, and other factors do not ensure an equal result.
In addition, realize that a reflashed ECU still utilizes many of the stock ECU’s learning functions. This means that in a perfect world, you will see the advertised HP from your reflashed ECU. This may also mean that on the day of dyno testing, your octane, the temperature, humidity, and many other factors are considered by the reflashed ECU when determining total power output. If the advertised numbers aren't there on dyno day, it doesn’t necessarily mean there is a problem, but rather, your ECU is protecting your engine from low octane, high temperature, high humidity, or other factors.
How much is a custom tune by a professional? Expect to pay $100-$150 per hour for the dyno time. Your tuner’s fee depends on their level of experience and pricing. Tuners generally charge $100-200 per hour for their time. The amount of total tuning time depends on the tuner and the amount of time you wish for them to tune your vehicle. Most tuners can get your vehicle within 90-95% of its maximum power within 1-2 hours.
Old 06-25-2005, 11:31 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
How do I go about learning tuning? The quickest source of tuning information lies with local DIY tuning personnel. Get to know locals via your local forum. Ask for advice, tips, and see some real world tuning. Also realize that tuning can become a very personal subject and there is more than one way to get to XXX power level. An excellent example of this is the U.S. vs Japanese tuning philosophy. U.S. tuners tend to run more boost and less timing and Japanese tuners tend to run less boost and more timing. Both can create safe power using these methods; it’s just using two different methods. While this is an over simplification and a generalization, this should give you the wisdom that there are different methodologies that people have successfully used.
Source of tuning information:
a. This thread and this thread though UTEC specific, contain tuning information that may serve useful for other engine management solutions.
b. For personnel interested in advanced tuning theory, or for professionals, consider the tuning articles on www.sae.org as a source of information.
c. How to Tune and Modify Engine Managements Systems by Jeff Hartman is a book dedicated to tuning that may prove useful.
d. EFI University offers classes nationwide on tuning fundamentals and principles.
e. Innovate Motorsports' website not only sells tuning products, but contains a wealth of tuning information.
f. UTEC Quick Tuning Guide While UTEC specific, this contains some good tuning information. (Requires registration on wrxhackers.com to view)
g. RomRaider FAQ
What are some helpful tools to use if I want to monitor my engine’s functions? Some engine management solutions come bundled with engine monitoring software, which is an excellent way to see hard data on your tuning results. If this software does not come bundled with your engine management, consider one of the following solutions:
Simple data logger
TARI DL1 (Diagnostics Level 1) Data Logger
DeltaDash
LogMapper
MPS UTECLogger
Auto-Logger
Scanmaster 3
What gauges/tools are important if I wish to tune my own vehicle? These are considered the "must have" tuning items:
a. Wideband O2 sensor/gauge
b. EGT gauge
c. Boost gauge
What are some other useful tuning tools?
a. Knock detection hardware
b. SMC 4 channel EGT
c. Useful tuning tools from Cobb Tuning
Editors Note
My special thanks to Trey Cobb and Daniel Ponze for their assistance in the formulation of this FAQ.
This post was created because I wasn't able to find a good engine management FAQ. I came up with the text based on LOTS of searching here. It was also created to be intentionally brand neutral so that it serves as a stepping stone for further research. Upon reading this you should have an idea of what type of engine management solution best suits your needs. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's engine management and it's great!" or "XXX's engine management runs too rich" are not appreciated here, that is what the Car Parts Review Forum is for.
Old 06-26-2005, 12:59 AM   #3
Call_me_Tom
Member#: 60972
This is great...when are you going to do a FAQ on tuning.
Call_me_Tom is offline   Reply With Quote
Old 06-26-2005, 02:14 AM   #4
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Default Suggestions put in FAQ
Suggestions deleted.
bofh is offline   Reply With Quote
Old 06-26-2005, 06:32 AM   #5
mistaboosta
Member#: 68722
that makes another FAQ sticky lol
mistaboosta is offline   Reply With Quote
Old 06-26-2005, 05:05 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I won't go into tuning as I have no clue myself. I'm more of a reflash guy myself.
I'm gonna skip the whole MBC issue as that really isn't engine management. MBCs are fine when used correctly on 02/03 by a judicious user. The issue gets further clouded on 04+ due to the open/closed loop delay. As well, I'm skipping air/fuel controllers for the same reason. Usually those two devices are used by either cheap skates, n00bs, or advanced users who combine them with other forms of real engine management.
The hyperlinks aren't the best, but it will take to long to reformat the whole page. I may add a link to openecu.org, but it will probably be awhile. They need to concentrate on tuning or theory rather than breaking into the ECU through various means. This isn't a disparaging remark by any means, but their goals differ from tuning and engine management.
My thanks for the suggestions both here and via PM.
Old 06-26-2005, 05:49 PM   #7
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Not sure this should be included but maybe make a note by the UTEC to say that it performs as a standalone in regards to fueling/ignition. Granted it literally is a piggyback, but it controls fueling/ignition itself not based off of ecu values. Just figured i'd throw it out there. Nice writeup.
P.S. Figured i'd post as your probably swamped with PM's.
Soon2Bgreat is offline   Reply With Quote
Old 06-26-2005, 08:24 PM   #8
Call_me_Tom
Member#: 60972
Linky no worky!
Old 06-26-2005, 08:25 PM   #9
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Unabomber,
Excellent FAQ as usual. This is exactlly the kind of information I need as I develope an interest in tuning my car. Please have it stickied to this forum. I have an AP and am running TARI DL1 to collect data. It's an overwhelming ammount of information, 77 variables last check, and I don't know what most of them mean. I look forward to a technical tuning FAQ that explains these variables and their interaction/relationship to each other.
Tks again...
STirocket is offline   Reply With Quote
Old 06-26-2005, 09:11 PM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
Wrong, that's a copout. Many aftermarket EM "solutions" are based entirely on those two issues. Boost Controllers (regardless of whether they're manual or electronic) and Fuel Controllers both should be addressed in any article that proclaims itself to be the Subaru "Engine Management FAQ."
For the first year the WRX was sold in the US, the only "EM" available was the DASTEK Unichip piggyback, which altered the MAF signal to "control" fueling and diddled with the crankshaft position sensor signal to "control" spark advance timing. And the Unichip isn't even mentioned in your FAQ? Both Vishnu and TurboXS offered Unichip "solutions."
Jon [in CT] is offline   Reply With Quote
Old 06-26-2005, 10:03 PM   #11
Sports Wagon
Member#: 43081
OMGHi2U
12345
Sports Wagon is offline   Reply With Quote
Old 06-27-2005, 12:33 AM   #12
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Deleted.
Old 06-27-2005, 11:47 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
The issue (mbc) gets further clouded on 04+ due to the open/closed loop delay. As well, I'm skipping air/fuel controllers for the same reason. Usually those two devices are used by either cheap skates, n00bs,
i think this is very important it should be listed at the very top of "why do i need EM" vs can i just install a MBC
the 02-03 DOES have the same problem but not as severely
a technical teaser of basics of ecus might be worth while (thinking out loud)
02-03 wrx cable throttle
04 wrx cable throttle ol/cl delay issues
05 wrx cable throttle ol/cl delay issues VIN coded into ECU
04 sti DBW avcs control
05 sti DBW, avcs control, VIN coded in to ECU, immobilizer key
and ill make a wild speculation
06 wrx DBW vin coded immobilizer key
Old 06-27-2005, 12:03 PM   #14
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Ron: Nice work! Something like this was needed. I do like how general you are since the real nit picky stuff really doesn't need to be included.
mbiker97 is offline   Reply With Quote
Old 06-28-2005, 08:58 PM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks for the advice folks, I've made some more updates based on ya'll's inputs.
Old 06-28-2005, 10:32 PM   #16
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
It's always nice to see folks give back to the community selflessly. Props dog, props
Mika
finnRex is offline   Reply With Quote
Old 06-29-2005, 02:17 PM   #17
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I made it into another FAQ.
Old 06-29-2005, 05:18 PM   #18
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Awesome FAQ Unabomber, you're the best.
So what's next on your FAQ list? Suspensions?
eltrouble is offline   Reply With Quote
Old 06-29-2005, 07:34 PM   #19
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I have some more updates to do (thanks Jaxx!), then yes.......Suspension FAQ is next on my hit list and I have a feeling it will be brutal with a capital B.
Old 06-29-2005, 08:23 PM   #20
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Yeah...suspension geometry isn't exactly a fun subject for anyone. Take your time with it, we really appreciate your work here.
Old 07-06-2005, 05:11 PM   #21
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
Thank you, thank you, thank you! I didn't see this one as a sticky, and I don't think it was up yet when I first started searching. Jaxx (thanks!) pointed this out and helps a ton.
Student Driver is offline   Reply With Quote
Old 07-11-2005, 12:02 PM   #22
slvrwgn
Member#: 32604
2003 Impreza WRX Wgn
This, like all of teh Unabomber's FAQs, is a great thread.
I have a question that isn't covered here, and that I've searched on but can't come up with a good answer. I thought I'd ask here and see what comes up.
When is EM really warranted? At what point is the stock ECU unable to adjust?
For example... I'm about ready to install an STi uppipe and Scoobysport downpipe (shorty) on my stock car. Does installing just an uppipe/downpipe warrant spending $800~ on having my car tuned.
Will I gain additional power, smoothness, AND safety by having my car tuned?
slvrwgn is offline   Reply With Quote
Old 07-11-2005, 12:19 PM   #23
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
By installing a catless up and down the turbo spools much easier. It is also able to run more boost, and leaner, safely. EM is always a good idea if you are looking to optimize your setup.
Even on a stock car EM is a good idea in my book.
Old 07-11-2005, 01:25 PM   #24
TurbojonLS
Member#: 38772
2 Cars, No Bling
Yup, but I'll add that I think EM should be the first mod you make. Some will say uppipe, and I can see this side of the fence. But the extra safety you get from a generic EM system, not to mention the extra power, is definitely worth it. Especially on the 04/05 cars. I don't think custom tunes are worth it at the stock level, especially if you're going to continue modding (and you will continue modding), but any of the generic maps (UTEC, AP, ECUTek) will be fine.
TurbojonLS is offline   Reply With Quote
Old 07-11-2005, 05:02 PM   #25
slvrwgn
Member#: 32604
Thanks for the responses guys, I really appreciate it. Based on what everyone has said I think my best bet is to install the up/down pipes and then take it in for a custom ECUTEK tune.
One more question, do you think it's safe to drive around with the up/down pipes installed for a week or two before getting tuned? I'd like to get a feel for how the up/down pipes change the car, and then also what difference the tune makes.
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
