Old 06-26-2005, 11:19 AM   #1
kheff46
Member#: 66739
2002 WRX wagon
Default timing belt 2.2l na
what is the average time it's taken any of you do replace the timing belt? i did the main seal at the same time, but it was relatively easy! i thought it was like a three hour job. just wondering!
kheff46 is offline   Reply With Quote
Old 06-27-2005, 10:38 AM   #2
kheff46
Member#: 66739
2002 WRX wagon
so nobody has done their own timing belt, or main seal? WEAK!
*moderator please close this post for the love of GOD!*
Old 06-27-2005, 09:42 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Are you asking how long it takes? And that's it?
three hours is a good amount of time to do this job. I know there are many people that can do it faster, but that's not really the point. Doing it right is much more important.
Tim Sanderson is offline   Reply With Quote
Old 06-27-2005, 10:23 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
As fast as I can unbolt and bolt the bolts. 20 minutes.
Old 06-28-2005, 09:32 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
that's what i was asking alright. i had done it in an hour flat, including main seal, and wasn't sure what book time vs. average mechanic time was. i guess that's about right then. thanks guys!
20 minutes? i'll let you do my next one then!
it took me more time to find the timing marks, than to do anything else! it'll be even easier if i have to do it again in 100k.
Old 06-28-2005, 12:30 PM   #6
Zebceponaf
Member#: 71371
'98 OBS
Hey I have to replace my t belt comming up real soon in my 2.2 SOHC. I've been trying to figure out what seals to replace and what i should order from subaru parts (here: http://www.subaruparts.com/diag/?mod...category=013-1 )
let me know, would be helpful
Zebceponaf is offline   Reply With Quote
Old 06-28-2005, 09:18 PM   #7
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Search "2.2 Timing Belt" in the Service & Maintenance forum. It seems like timing belts are summer jobs. I remember last year there was a plethora of timing belt changes. Legacy777 has some nice pictures floating around too. Do a search for user Legacy777 and timing belt.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 06-28-2005, 10:28 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I think 20 minutes is a little ambitious. I'd love to see that.
Pull fans
remove crank sprocket/bolt
remove timing covers
align timing marks
remove two left side idlers
remove tensioner
remove belt
remove old front main seal
install new front main seal
compress tensioner correctly and "pin" it
install belt
install tensioner
install both left side idlers
Double check timing marks and torques
pull tensioner pin
put timing covers back on
put crank sprocket back on and torque the bolt
install the fans
20 minutes? MAybe, but I doubt it.
Old 06-28-2005, 11:37 PM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Impact wrench baby.
I just video taped it. Took 15 minutes with me talking and showing how to do it.
But I will admit a few things.
Motor out of wagon. Precompressed tensioner. Didnt replace the seals. Those add alot of time.
But if you have air tools, you can really really cruise!
This video will be hosted on Legacy Central sometime next week. It is also be available on DVD along with motor rebuild basics.
Old 06-29-2005, 09:29 AM   #10
kheff46
Member#: 66739
2002 WRX wagon
that's wicked fast! i used an air ratchet the second time, that made a difference for sure! i couldn't break the pulley(main) bolt free, so i had my old man hold the ratchet(with cheater pipe) and i cranked the starter. VOILA! no problems the second time around, probably age welded itself(rust).
i think i threw the bag and box from parts away, let me check my invoice for a number!
i got it through a parts distributor, not subaru. which means half price and then some! part #'s may be different than suby dealer's. i'll post tonight or tomorrow!
FS: WRX rear diff, half shafts, crossmember, 2.2L NA engine and some other stuff speedyHAM Private 'For Sale' Classifieds 28 02-19-2005 11:06 AM
A good source of 2.2L NA pistons ? G.Subramaniam Normally Aspirated Powertrain 11 11-04-2004 05:25 PM
do WRX headers bolt on the 2.2L NA 96 block crk4 Normally Aspirated with bolt-on Forced Induction Powertrain 14 12-05-2003 04:56 AM
Injectors for a 2.2L NA engine? yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-04-2002 11:37 PM
