Old 06-27-2005, 10:29 AM   #1
doofus
Member#: 49591
Default engine stumbling and stall
i've got an 03 wrx, stock with 10K miles. the engine will stumble and can't maintain idle after coming to a stop. quickly gunning the engine in neutral doesn't help as the engine starts wildly changing its RPMS as soon as throttle is lifted. this morning, it stalled completely.
any ideas? i'm about to bring it in but its a bit worrisome.
fuel filter, air filter...?
danka
doofus is offline   Reply With Quote
Old 06-27-2005, 12:15 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Could be a dirty idle air control valve. My car was having trouble idling recently much like what you described, although it never actually stalled on me. I cleaned it out with Seafoam and that solved my problem.
If you attempt to DIY, be aware that there is a coolant line running through there, so only remove the valve (which sits on top of the throttle body) when the engine is cold. There is a rubber gasket, part number 22659AA120, that might need to be replaced--I bought a new one just in case. Also, the two screws that secure the valve in place are very soft and were tightened at the factory by the Subaru gorilla, so be careful with them.
Zola is offline   Reply With Quote
Engine idle funny and stall??? Mike7 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-09-2008 05:14 AM
Stumbling and Stalling on start? Braz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 07-17-2005 11:00 AM
Boost = stumble & stall WRXin19087 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-03-2004 02:38 PM
engine stumble after mod? Gregwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-04-2002 10:17 PM
OBS stumbling and stalling on start-up? Diz Normally Aspirated Powertrain 2 06-13-2001 07:14 AM
