06-27-2005, 10:43 AM | #1 |
Member#: 7107
TXIC
Vehicle:2014 Mustang GT White |
Cobb ecu question.
My ecu was flashed before the A _Port came out. I then purchased the AP for an ecu that was already flashed. I am now selling the car, and want to know if I can unmarry the AP from the car, and sell the unit. Otherwise, I will have to find another 02 owner and swap ecus (5speed).
thanks And yes, I am waiting to call in to Cobb this morning.
06-27-2005, 11:33 AM | #2 |
Member#: 33410
Vehicle:08 wrx dgm |
you had an ACCESSECU
bought an accessport upgrade version. want to unmarry the accessport and sell it? should work, I've asked cobb this question myself. |
06-27-2005, 11:54 AM | #3 |
Member#: 7107
TXIC
Yep. I hope it works. But, I would think that it would only work on other cars with the Access ecu flash.
06-27-2005, 04:28 PM | #4 |
Member#: 33410
from what cobb has explained to me. Your ECU has the accessecu license on it. When you bought the AP upgrade version that AP was coded to look for a licensed ECU when marrying.
according to Cobb when you unmarry and revert to stock, the AP flashes the a stock-like map to the ecu and erases all traces of the accessecu license and data information. At that point the AP going into "new" more and should be able to be used on any compatable (MY02-03, MY04-05,etc) ECU. I'm betting on that when I sell my car this summer/fall. |
06-27-2005, 04:55 PM | #5 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
so if i had a flashed ecu, then got a ap on, then unmarried it, is the ecu still flashed?
06-27-2005, 05:33 PM | #6 |
Member#: 60324
Vehicle:1998 RS |
yes and no.
The ap will "flash" a stock like ROM file to your ECU, which completely imitates the stock map in every way. However, it removes the license, so you can use the AP on another car. THere is certain memory in your ECU that is "overwritten" when you flash your car, and the only way to get it back is to overwrite it again, and the ap overwrites the info with "stock" info and removes the license with a revert to stock option. phew. |
06-27-2005, 06:10 PM | #7 |
Member#: 63083
RMIC
Vehicle:2002 WRX MBP |
once you unmarry it, you will have cobb's version of a stock map...i.e, as most stock as you're gonna be able to get besides buying a stock ECU.
ive done this numerous times, (installed accessport upgrade on an already accessecu flashed ECU and then unmarried it. the previously flashed ecu will go back to cobb's version of the stock map) it works perfectly fine. and you can then sell the accessport to somebody with a stock ecu. as long as you unmarry properly, it will work fine (also done this as well) on another note, i don't know how people can mess up installing/uninstalling accessports...follow directions step by step and you're golden |
06-27-2005, 06:19 PM | #8 |
Member#: 56203
i did the same thing but i thought i could get some money for the ecu too
06-27-2005, 08:56 PM | #9 | |
Member#: 7107
TXIC
FS-CA: cobb ecu, greddy recirc bov, stock ecu | BlueBerryRex | Private 'For Sale' Classifieds | 7 | 01-19-2005 04:50 PM |
Turbo-back exhaust question - scoobysport + cobb ecu ? | wrexington | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 04-12-2004 02:51 PM |
Cobb ECU reflash: anyone with any experience? | NETWRX | Engine Management & Tuning | 0 | 04-12-2003 10:57 AM |
cobb ecu reflash dynographs | virpacalis | Engine Management & Tuning | 0 | 04-07-2003 12:11 PM |
Cobb ECU Upgrade | RSRacer | General Forum Archive | 20 | 05-10-2000 09:28 PM |
