Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 06-27-2005, 04:26 PM   #1
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
Default utec question changing to MBC from utec boost
what setting do i have to change on the utec if i want to change from the utec controlling boost, to using a manual boost controller? sorry for the nooob question but i just want to make sure i dont screw anything up!
trbowrx is offline   Reply With Quote
Old 06-27-2005, 05:35 PM   #2
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
anyone?
Old 06-27-2005, 05:43 PM   #3
TurbojonLS
Member#: 38772
2 Cars, No Bling
If you install the MBC correctly, it doesn't matter what you have the in any boost sections of the UTEC - the MBC will be the only thing between the boost source & the wastegate, so it will be the only thing controlling boost.
TurbojonLS is offline   Reply With Quote
Old 06-27-2005, 05:43 PM   #4
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
The other two maps run off of MAP, so if you set boost to ECU control and use the EBC, the fuel / timing will work anyway.
dosage0 is offline   Reply With Quote
Old 06-27-2005, 08:28 PM   #5
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
so i dont have to change anything in the settings?
Old 06-27-2005, 08:42 PM   #6
Division By Zero
Member#: 7555
Boost will likely come on quicker. What this means is that you will probably have to change some of your vertical % columns (both timing and fuel) in UTEC to make up for the change in boost response. You will need to reference your AFR though to do this.
Division By Zero is offline   Reply With Quote
Old 06-27-2005, 11:26 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
I don't think so. If you're using the basemap(which it seems like you might be), you should be fine tuningwise if you use an mbc or the utec boost control. You might get part throttle full boost though. Make sure that when you're below the tps crossover(which is set in the parameter section of the utec(in the olf section if you're using utecs olf mode)), the boost doesn't go that high. If the boost goes above say 8psi(or so) below the tps crossover, it would probably be wise to either lay off the throttle so the boost goes down, or push the throttle past the tps crossover point.
peace
Old 06-27-2005, 11:43 PM   #8
Division By Zero
Member#: 7555
TPS is set to IIRC 25% so I don't think he'll get too high of boost. Try putting it down to 20% cross-over though.
Old 06-28-2005, 07:15 AM   #9
hippy
Member#: 36528
2002 Impreza Wrx
That depends on his setup and how his utec is set. If he's not using utecs olf mode, the lowest the tps crossover can be set to is something like 60%. Also, a stock wrx turbo can run a lot more then 8psi at 20% tps depending on the rpm and load.
peace
Switched to Cobb from UTEC Nudzbone Tri-State Area Forum 6 02-06-2008 12:39 PM
likely to change to 4EAT FROM 5MAN Meat Supply Transmission (AT/MT) & Driveline 13 02-07-2007 02:08 PM
Thinking of going to Link from UTEC. Kwyjibo Engine Management & Tuning 8 02-22-2004 05:09 PM
I felt power loss after going back to MBC from Unichip/MBC txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-09-2003 10:01 PM
power expected to gain from UTEC with my mods? whiterabbit Engine Management & Tuning 3 02-17-2003 12:50 PM
