Old 06-27-2005, 04:42 PM   #1
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
Default Will the instrument cluster from 2dr. 2.5RS fit a '98 OBS?
My speedometer doesn't work so well so I am looking to attempt to fix it, but if that doesn't work, I just want to replace it. I found an instrument cluster for a 2.5RS and was wondering if that would work in my car (plus I like the look of the 2.5RS cluster better)
Thanks
Also, would I be able to swap out the odometers? (I can figure that out...)
Thanks!
RootUsr is offline   Reply With Quote
Old 06-27-2005, 06:01 PM   #2
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
well... the dealership wasn't any help, though it was kind of fun to 'hear' the look on their face when I asked the question :-D
Old 06-27-2005, 07:37 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If it's from the same year, I would expect it to work; you could ask at a Subaru dealer if the cluster from the '98 RS & OBS have different part numbers or not.
The odometer thing is a can of worms. Depending on your state laws, you will likely have to at least attach a sticker to your car indicating the mileage at which the old cluster/odometer was removed and the mileage on the new one when installed. Even with that, it will likely knock some value off your car when (if?) you ever go to sell it.
Have you tried contacting a speedometer calibration/repair shop?
Old 06-27-2005, 09:01 PM   #4
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
[edit]Thanks for the reply!
didn't mean to sound like a jerk with my reply[/edit]
I know that they are different, I just don't know how different they are... (the face on mine is black, while the RS is white, that's the extent of my knowledge in the matter)
so that's one difference... I mainly am interested in whether or not the speedo will match up, everything else can be... fixed
Will rad fans from '00 2.5RS fit a '99 LGT? TaurusMcRae007 Normally Aspirated Powertrain 9 06-30-2009 04:34 AM
will a gauge cluster from a 02-03wrx fit 06? mdd1986 Electrical & Lighting 0 06-18-2006 01:30 AM
would the gauge cluster from an '00 2.5rs fit my '99 OBS? kaisersouse Electrical & Lighting 0 06-28-2005 12:33 PM
Will the front CV Axles from a 2.5RS fit my 95 L? marcus12 Transmission (AT/MT) & Driveline 4 07-30-2004 10:01 PM
Will the turbo manifold from a 2.2 fit a 2.5RS??? Xscreamer Factory 2.0L Turbo Powertrain 3 06-10-2001 08:13 PM
Message Board Statistics All times are GMT -4. The time now is 12:04 PM.
