Old 06-27-2005, 07:09 PM   #1
damonmlime
Member#: 54525
2000 00rs 2x91ss 95l
blue ridge pearl
Default 91ss electrical problem
i have a 91ss 5speed 147k and it has a weird problem. when i first got it it had a weird hesitation, i changed plugs, wires, iac valve, fuel filter, maf sensor, air cleaner and everything else i could think of. one day i got the bright idea to clean the battery terminals and charge the battery. after i did that the car ran great for a few hours, then the hesitation came back, so i swapped alternators and batteries and that didn't help. i think i have some electrical issue, when you rev the car and let it go back down to idle if you hit the brake, the time on the stereo blinks or dims, i think the alternator is putting a drag on the engine, anyone got this problem or a solution? thanks damon.
damonmlime is offline   Reply With Quote
Old 06-28-2005, 12:09 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
bad ground
Old 06-28-2005, 05:34 PM   #3
damonmlime
Member#: 54525
blue ridge pearl
that's what i was thinking but where is the ground? is it just the ground wire on the battery? thanks damon
Old 06-28-2005, 06:49 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
There's a second ground you probably can't see that is under the intake manifold for the wiring harness...
Old 07-02-2005, 12:18 AM   #5
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
hey damon,
i think that ground wire is bolted into the block, right about where the engine meets the tranny, it might be a little more foward, but thats where mine was for my 1.8 and 2.5.
Also side note, dont know the condition, but tyler just got a 92 SS for 100 bucks back home for him in petersburg, has a blown trans, thats it though....
-mikey
mcu81 is offline   Reply With Quote
Old 07-04-2005, 12:35 PM   #6
ultrasonic
Member#: 18006
My 91 SS does this also. It runs well usually, but has a rough/low idle when warm.
ultrasonic is offline   Reply With Quote
Old 07-31-2005, 12:19 PM   #7
snowjob
Member#: 59357
2009 Forester XT
Try cleaning all of the ground points on the chasis, their is one behind the right hand shock tower, one on either side of the engine on the fram, you just need to look at the frame beside the engine block, it's a bitch to get at. I think that's it, but I may be wrong. Undo all of these points, including the bolt to the altanator, and clean them back to shinny metal.. It made a huge difference in my SS.,
snowjob is offline   Reply With Quote
('93-'01) Help!! Legacy Electrical Problems mhj Impreza Forum 4 07-26-2001 07:32 PM
('93-'01) Please help - Electrical problems Boeleni Impreza Forum 2 04-08-2001 08:53 AM
Electrical problems? Bohanan Texas Impreza Club Forum -- TXIC 6 12-24-2000 05:18 PM
Static electricity problem dead-eye General Forum Archive 36 12-08-2000 09:40 PM
Weird electrical problem JJTheSubeDriver Car Audio, Video & Security 4 01-28-2000 08:23 PM
