Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-27-2005, 08:35 PM   #1
basicwrc78
Member#: 55715
1956 Syrena 105
1985 126p protuned
Unhappy Got problem !
Hi guys , I got problem with my 2002 wrx. I drives well but from like two days once or twice per day during driving all electricity in car is turning off for about one second and then turning on again.
Any suggestions what could it be?
BIG THANKS FOR HELP!
basicwrc78 is offline   Reply With Quote
Old 06-27-2005, 08:40 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Especially if you (or the previous owner) had a lot of stuff hanging from the keychain of the ignition key, it could be that contacts in the ignition lock mechanism are worn out/corroded/dirty from arcing, causing an intermittent problem. Try wiggling the ignition key with the car on to see if that causes the problem. You can disassemble & clean the mechanism, or even buy a new one.
Old 06-27-2005, 09:50 PM   #3
2phless
Member#: 69343
1998 TransAm cnvrtbl
Does the engine die/ try to stall along with it?
I'm guessing radio cuts out. AC blower, dash lights? Speedo/tach drop to 0?
I like armand's theory though. That or an important fuse (pehaps under the hood in that fuse box) has been tapped to power something? Fuse taps spread the factory terminals and can make a fuse break contact intermitantly.
2phless is offline   Reply With Quote
i got problems with my headlights UneKRON Interior & Exterior Modification 3 01-26-2004 11:54 AM
Just installed Es100's Got problems DRIVER1 Tire & Wheel 8 01-04-2004 06:01 PM
I got problem, I need help-intake Wellhung Normally Aspirated Powertrain 5 08-22-2002 11:49 PM
OMG -- We got Problems md2001rs Mid Atlantic Impreza Club -- MAIC 7 11-21-2001 05:14 PM
Got problems, broke one of my belt tensioners pwrup25RS Technical Forum Archive 0 07-17-2000 01:50 AM
