Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 06-28-2005, 10:10 AM   #1
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Default Is the end near? (More Subaru problems)
So the official diagnosis is slowly being put together on my car... and it is leaning towards the headgasket failing AGAIN.
The symptoms:
1. coolant resevoir is full and overflowing
2. coolant appears to be boiling
3. car will overheat if it sits still too long (will run fine on highway type driving... thank god since it started this up 500 miles away from home)
4. Coolant is not being pulled back into the radiator once it is sent to the resevoir.
5. Car is consuming large amounts (1 quart in the 500 miles trip home) of coolant... I think it is really just coming out of the reservoir bottle instead of being burned off or leaked out.
Any thoughts?
It looks bad and makes me think headgasket... if it is the HG, this will be be the death of this car in its present form... I will either go through with my planned swap NOW or fix it, sell it and buy something else (and not a Subaru... three headgaskets failing in 2 years is too much)... :sigh: this car and I have such a love/hate relationship... when something breaks on it, it is NEVER something small...
Texas25RS is offline   Reply With Quote
Old 06-28-2005, 10:14 AM   #2
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
maybe its a radiator issue?
welcome to the world of "its never a small issue"
KevinHeist is offline   Reply With Quote
Old 06-28-2005, 10:25 AM   #3
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
yep, it could be something small like a thermostat or radiator (ok, radiator isn't small) that is causing the HG to pop once the water starts to boil.
you should really look into getting the cooling system completely flushed out. even if there is a passage somewhere in the block that is clogged it can cause problems of this nature.
Old 06-28-2005, 10:41 AM   #4
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
2 weeks ago...
1. radiator pulled, pressure tested cleaned and pressure tested again
2. All hoses replaced on front of engine
3. Water pump replaced as it was seaping coolant
4. Timing belt replaced
5. AC and PS belts replaced
6. New radiator cap installed
7. New thermostat installed
8. Flushed and filled
So let me rule all of that out...
Thank god all ofthat only cost me $180 in parts and no labor.... or I would be really pissed at this point...
Old 06-28-2005, 10:56 AM   #5
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
did u do the work urself?
i guess ur not doing the s2k autox
stickman is offline   Reply With Quote
Old 06-28-2005, 11:00 AM   #6
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
No a very experienced mechanic did the work as he was showing me how it was done... and no on the race... especially now...
Old 06-28-2005, 11:40 AM   #7
el tekk-O
Visiting NASIOC Timeout
Member#: 65223
2002 WRX-6 speed
130000 miles
warped cylinder heads
ive had this happen to me before, same symptoms (on a VW)
el tekk-O is offline   Reply With Quote
Old 06-28-2005, 11:52 AM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
So the last headgasket failure warped the heads resulting in this? Sounds plausible.
wcbjr is offline   Reply With Quote
Old 06-28-2005, 12:41 PM   #9
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
time to get a WRX motor in there!!
OneArmedScissor is offline   Reply With Quote
Old 06-28-2005, 12:45 PM   #10
haloseven
Member#: 34683
2015 WRX Premium
Ice Silver
gruppe-s has some FXT 250 HP Motors on sale. Do it.
haloseven is offline   Reply With Quote
Old 06-28-2005, 01:01 PM   #11
DarkShadow
Member#: 17615
2009 Toyota Tundra
It sounds like the cooling fan may be out. check the theromstat and the fan relay. My mom's escort did the exact same thing.
DarkShadow is offline   Reply With Quote
Old 06-28-2005, 02:42 PM   #12
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
I've got a nice coolant leak as well.....fortunatly mine is the hose going to the turbo. Not good news, but at least fixable
YourMother'sLover is offline   Reply With Quote
Old 06-28-2005, 02:48 PM   #13
gforced
Member#: 38898
Man, that sucks. Come out to the next race Casey and I will let you drive my car.
gforced is offline   Reply With Quote
Old 06-28-2005, 10:41 PM   #14
couldnthinkaone
Member#: 2944
2000 2.5RS
Steel Blue Mica
make sure the fan is working...sounds like it's not...
couldnthinkaone is offline   Reply With Quote
Is the GT worth more than the L? ShaneW Legacy Forum 26 04-12-2011 10:54 PM
So far in OT today - is the apocalypse near? OriginalSin Off-Topic 31 12-07-2005 01:57 PM
So, 2006 is the end of the Baja 10.5sec1992AWDtalon Baja Forum 85 09-19-2005 09:35 PM
Versus said my car is the least JDM looking Subaru, how can I make it look more JDM? JDM addict Member's Car Gallery 130 09-16-2005 08:08 PM
