#1 |
Member#: 47803
Vehicle:2000 Impreza 2.5 RS Blue Ridge Pearl |
Im burning oil (not in the combustion chamber but oil is dripping onto the hot exhaust and/or engine block. Every time I stop or park in my garage it smells like burning oil. Im not sure were its coming from, the oil pan is pretty clean, i just did valve cover gaskets and spark plug O-rings, what else can it be? The oil looks is manly dripping off the cross member onto my swaybar then dripping onto the exhaust.
Is it a leaky separator plate? Is there anyway to make sure it is the separator plate before I drop the tranny and realize thats not the problem? If it is the separator plate is there anything else i should do while i have the tranny off? ~Leor
#2 |
Member#: 54709
Vehicle:1995 IMPREZA 1.8 4WD |
I don't know anything about a seperator plate. 1st I'd check to make sure replaced valve cover gaskets don't leak. Look around them completely w/a mirror. Also pay attention to little rubber grommet / washer things you should have received with new valve cover gaskets.
Next most likely scenario is cam & crank front seals. Go out at about 100k / 8 or 10 yr interval. leak like crazy! diagnosed this prob w/wife's car by thoroughly pressure cleaning bottom of engine, then checking back a few days later to see where it was coming from. I was initially convinced it was a rear main, but turned out to be front seals where oil would drip from t belt cover while driving & be blown back onto exh, crossmember, etc. Also as last resort maybe rear main seal? ours leaks a little but i don't feel like fixing until it leaks a bunch. goodluck |
#3 | |
Member#: 47803
~leor |
#4 |
Member#: 52985
I had the same problem! My oil drain plug seal wasent/isnt doing its job. Oil is leaking ony header and burning off
#5 |
Member#: 40674
SCIC
Vehicle:94 Impreza wagon 1.8L + 657cc's |
I'm willing to bet its a crank or oil pump seal...its a common Subaru problem.
Your description of the oil covered header is exactly what happened to me...I finally got tired of having smoke envelope the car when at a stop and replaced the seals. The parts are really cheap, but you're gonna have to take your timing belt and related crap off to access the seals...have fun. -Lyle |
#6 | |
Member#: 47803
) ? and by crank seal you mean the rear (main) seal right? and if so does that involve dropping the tranny?~Leor |
#7 |
Member#: 40674
SCIC
The front end of the crank goes through the oil pump...or should I say the oil pump is directly behind the crank pulley. There are both a front and rear seal, im pretty sure.
With my car, I could see that oil was dripping down from the front of the engine, so I knew it was the oil pump. If you have the same problem, you will need to buy an oil seal which seats into the oil pump, and a little oil pump o-ring. I've never replaced a rear oil seal, but by looking at the service manual, it looks like you'd probably have to drop the tranny. Last edited by GFimpreza; 06-29-2005 at 08:20 PM. |
#8 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper Wagon |
To do the rear crank seal or the oil seperator plate, you need to drop the trans and pull the flywheel.
SOA used the plastic oil seperator plate for a couple of years before going back to the aluminum one. The plastic ones leak over time. So, I would pull front timing covers and clean things up real well. Go driving and check for leaks. These seals are the easiest to replace. Also the oil pump can leak, but you can still see it. Rear crank seals and oil seperator plate leaks are harder to see. |
#9 |
Member#: 48968
Vehicle:1999 impreza 2.5RS silver |
anybody have the part number for the metal or plastic oil seperator plate?
thanks |
| Thread Tools | |
| Display Modes | |
| burning oil smell after oil change | happs subi | Factory 2.0L Turbo Powertrain | 17 | 12-02-2009 12:37 PM |
| HELP!!! burning oil smell, turbo smoking? | mattarmada | Service & Maintenance | 5 | 10-14-2009 12:40 AM |
| Burning Oil Smell | Scooby2 | Newbies & FAQs | 9 | 03-22-2007 02:53 PM |
| burning oil smell after oil change? | wrxinfx | Service & Maintenance | 4 | 12-12-2001 09:13 AM |
