Closed Thread
Old 06-28-2005, 05:00 PM   #1
RS Paul
Member#: 87520
Default Impreza 2004-2005 headlight wiring diagrams
I've just drawn up some wiring diagrams to help me understand the
headlight system for 2004 and 2005 Imprezas. Those of you considering
adding or modifying fog lights or driving lights may find them useful.
It took me a long time to figure out what was going on even with the
factory manual. Hopefully these drawing can save someone some pain.
Wiring diagrams
I haven't produced anything new, just put together info from various
places off the internet and from the service manual.
Feel free to use them as you see fit, I only ask that no one copyright
them as I had happen with some other work. You can PM me with any
comments or corrections and I'll update the drawings.
The resolution of the drawings is not the greatest but they print pretty
well. I can provide the original drawings in Micrografx Designer 7 format
which are much clearer and are editable.
Thanks to all those that have gone before, they made things much
easier.
RS Paul is offline
Old 06-28-2005, 05:14 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You show the low beams going directly to ground when not in DRL mode, this is not accurate. They are switched to ground through the headlight switch.
Good work though-
Mulder is offline
Old 06-28-2005, 06:58 PM   #3
RS Paul
Member#: 87520
In my service manual (2004) on page WI-135 are shown two
different grounds "REF.TO GND-02" for the headlight switch and
"REF.TO GND-03" for the daytime running light relay and the
daytime running light resistor. When the lowbeams are turned
on the daytime running light relay switches to change the ground
path for the lowbeams from going to the resistor (then to ground)
to go directly to ground.
The lighting switch grounds the daytime running light relay coil,
not the lights themselves.
RS Paul is offline
Old 06-28-2005, 07:13 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, I see what the problem is. You are basing your diagrams on the wiring for the 04-05 which is a dual-beam system and keeps the low beams on as long as the headlight switch is on. The 02-03 is NOT the same, it is a single bulb/dual filament system that turns off the low beams when the highs are on. Hence the wiring is different.
Although you indicate that the diagrams are for 04-05 on the diagrams themselves and in the text of your thread, you also need to do so in the title. I'll fix that for you.
Mulder is offline
Old 06-28-2005, 09:06 PM   #5
RS Paul
Member#: 87520
Thanks Mulder. I changed the title on my webpage. I was only guessing
about 2003 since the cars seem pretty similar. I also wondered if these
drawings would also apply to 2006s but I guess I'll have to wait to see if
they've changed things (again) or not.
RS Paul is offline
Old 05-15-2013, 08:24 PM   #6
V1P3RSRTX
Member#: 353300
2004 Impreza 2.5rs
I know this thread is slightly old but I would like to inquire as to if anyone has a schematic for the grey 4 conductor connector that is the clip connector for the DRL/LB headlight in the 04/05 Imprezas.
If you happen to know the voltage and amperage on each line also that would be quite helpful. Looking to mod an aftermarket HID Halo to take the place of the DRL's if I can.
V1P3RSRTX is offline
Old 05-15-2013, 11:41 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please don't bump ancient threads.
Mulder is offline
Closed Thread
2004 headlight wiring diagram question RS Paul Electrical & Lighting 3 10-09-2005 10:02 PM
Seeking Headlight Wiring Diagram for Headlight Timer JackClark Electrical & Lighting 2 03-13-2005 09:32 AM
BG stock headlight wiring diagram needed monovich Legacy Forum 6 09-09-2002 06:16 PM
New Age MY02 RS Headlight Wiring Diagrams Josico Interior & Exterior Modification 6 12-26-2001 04:13 PM
