Old 06-28-2005, 07:14 PM   #1
simple monkey
Member#: 81067
1989 RX, FX16
both white
Default oil cooler
I recently bought an oil cooler ($6.50) and I'm curious about where to plug it in? i have a Ea82T. Anything helps.
Thanks
-Victor
simple monkey is offline   Reply With Quote
Old 06-28-2005, 10:59 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
What kind of oil cooler is it? Can you post a pic of it? What size are the lines to and from it?
Tim Sanderson is offline   Reply With Quote
Old 06-28-2005, 11:40 PM   #3
simple monkey
Member#: 81067
1989 RX, FX16
both white
cant post any pics right now, but it is the large oil cooler out of an old Mercedes Benz 300SD diesel wagon. It has 7/8" male connections on both sides. I dont have lines of fittings for the other parts. Its the black one in this link, but older and broken in.
http://www.autopartswarehouse.com/re...placement.html
Flame Guard Sleeving for Oil Cooler/Differential Cooler Hoses vpwseah Engine/Power/Exhaust 0 09-10-2007 07:19 PM
Top mount Oil cooler/tran cooler ColesSTi Factory 2.0L Turbo Powertrain 5 08-31-2006 08:10 AM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain 3 10-28-2002 09:40 AM
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? ChristophWRX Factory 2.0L Turbo Powertrain 6 06-04-2002 12:48 AM
Message Board Statistics All times are GMT -4. The time now is 05:00 PM.
