Old 06-28-2005, 09:00 PM   #1
brcewane
Member#: 63990
Flat Grey
Default New fiberglass project.. EVO like gauge pod
Just about to start into my next fiberglass project. This time I am working on a gauge cluster for the center console... the idea is going to follow the same kind of style as the gruppe-s EVO cluster seen here:
I am moving my single din stereo down and putting the gauges up above it molded into the trim piece so that it flows much like the evo piece.
Here is a really crappy MS paint to give the overall idea
I'm pretty sure I am going to have to do some trimming in behind it to make it all work but it should be fun to build.
brcewane is offline   Reply With Quote
Old 06-28-2005, 09:44 PM   #2
Member#: 67
1999 Outlasting
the competition.
what size gauges? i think they already make a single din one for the 52mm ones.
i could be wrong..
i have that same pod on the evo. decent quality.
Tom
Old 06-28-2005, 09:46 PM   #3
intence
Member#: 58477
. Member #1 of
the witty MS Crew
intence is offline   Reply With Quote
Old 06-28-2005, 09:52 PM   #4
ittybitty_STI
Member#: 78815
2005 LGT
Atlantic Blue
Thats a good look i like that. i like the cf pod that takes place of the clock.
ittybitty_STI is offline   Reply With Quote
Old 06-28-2005, 10:03 PM   #5
Gordata
Member#: 86891
2002 WRX Wagon VF22
looks good, was thinking of doing the same
Gordata is offline   Reply With Quote
Old 06-29-2005, 07:42 AM   #6
brcewane
Member#: 63990
Flat Grey
yeah, I am using the 52mm ones.. I just wanted to mold them in to give them more of a built in look
Old 07-05-2005, 08:37 AM   #7
brcewane
Member#: 63990
Flat Grey
UPDATE....
Started my fabrication... basically grinding out the areas to make the 52mm gauges fit.. I am trying to make the gauges line up with the three HVAC controls on the bottom. I should be getting the actual gauges tonight or tomorrow so I will be able to make some quicker progress then.
Old 07-05-2005, 12:19 PM   #8
WRXSIG
Member#: 83660
2013 WRX
Ice Silver
holy **** hackjob batman!!! dude you should have waited for the gauges to come in....totally wrong way to do it.
WRXSIG is offline   Reply With Quote
Old 07-05-2005, 12:25 PM   #9
brcewane
Member#: 63990
Flat Grey
why would that be the wrong way to do it??? it is all getting fiberglassed to look built in... you won't even see any of that stuff where it got hacked out. Don't see why it will be a problem
Old 07-05-2005, 03:55 PM   #10
WRXSIG
Member#: 83660
2013 WRX
Ice Silver
i would have personally waited...bacause the back part of the gauges are smaller than the front faces...so you could have possibly made the holes smaller...but if your doing the whole surround than thats prolly fine.. should come out cool though...
Old 07-05-2005, 04:37 PM   #11
brcewane
Member#: 63990
Flat Grey
Yeah, the white circle there is actually the back of an old Autometer 52mm gauge.. the screw on piece that comes with every autometer gauge.. so the hole should be good...
The gauges are in, so I will be doing some more work tonight
Old 07-05-2005, 05:47 PM   #12
Sanchez
Member#: 51002
2005 Pig STi
Turbo Negro
d00000d nice project... if you get it goin and start selling them let me know. I miss my clock
Sanchez is offline   Reply With Quote
Old 07-05-2005, 06:04 PM   #13
ludecrous
Member#: 19376
2003 03 WRX Wagon
curious to see the results could turn out awesome. ... nice.......
ludecrous is offline   Reply With Quote
Old 07-06-2005, 07:14 AM   #14
brcewane
Member#: 63990
Flat Grey
Gauges have arrived, didn't have time to work on it last night... tonight is time to get busy
Old 07-06-2005, 05:11 PM   #15
Nat
Member#: 759
2004 WRX
2000 SV650
I've seen your fiberglass handywork in the audio forum, so I have faith! Looking forward to the final result.
Nat
Nat is offline   Reply With Quote
Old 07-07-2005, 12:06 AM   #16
aaronSTi
Member#: 88813
that will look awsome
aaronSTi is offline   Reply With Quote
Old 07-07-2005, 10:06 AM   #17
brcewane
Member#: 63990
Flat Grey
Progress under way. Picked up some supplies and got started on my gauge mounting.
First was drilling the holes for the gauges in some plastic I found at Home Depot that had a nice 90degree lip on the bottom.. just what I was looking for. Then used a 2" hole saw for the gauge holes. Works nice and the gauges sit snug in them.
Then had to do some more trimming of the trim piece and the plastic to make it fit just right. I was wanting to make sure that the holes cut for the gauges would line up over the HVAC controls for some symetry.
I also wanted to make sure that the top of where the single din slot was looked like the angled top of the stock trim piece to make it look more factory..so some trimming was involved there
Then I used a glue gun to temporarily hold it in place so I could start with the body filler. This picture is just after the first layer and sanding of the filler.. lots more finishing work to do
Here are a couple of more pics with it in the car.. in the second picture the gauges are sticking out a bit and not sitting flush just because I wanted a test photo and didn't want to fight to get them back out since they are snug. In the end it will all be painted silver and I will paint the trim pieces above it as well so the colors all match.
Old 07-07-2005, 10:17 AM   #18
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Nice, that's going to look great when you're done! Are you going to recess the gauges a bit to match the HVAC controls? That would be killer ...
Car vs. Driver is offline   Reply With Quote
Old 07-07-2005, 10:17 AM   #19
ludecrous
Member#: 19376
2003 03 WRX Wagon
looks cool so far
Old 07-07-2005, 10:50 AM   #20
brcewane
Member#: 63990
Flat Grey
That was my initial intention.. but unfortuneatly just isn't enough room to do so.. it is a really tight fit and I had to trim out a bunch to get the 52mm gauges to go in...
But you are right.. it would look killer.
Thanks for the compliments
Old 07-07-2005, 11:13 AM   #21
russd32
Member#: 63961
Berrry Berry Nice Mon!
russd32 is offline   Reply With Quote
Old 07-07-2005, 11:15 AM   #22
jojor512
Member#: 19311
2002 Lexus IS300
Black 5MT
looks really cool, but personally I would do away with the chrome surrounds, even if it means mounting the gauges to the back of the bezel
jojor512 is offline   Reply With Quote
Old 07-07-2005, 11:32 AM   #23
Damon
Member#: 2902
i hate all you people with mad fiberglassing and carbonfibering skills.
Damon is offline   Reply With Quote
Old 07-07-2005, 11:34 AM   #24
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
ok, i know i'm a complete noob when it comes to fiberglass/carbon fiber, but where is either of these in the project? don't get me wrong, i think it will look awesome, but as far as i can see it's just plastic and body putty, which will be then prepared and painted.
CletusTheDwarf is offline   Reply With Quote
Old 07-07-2005, 11:45 AM   #25
stevepius
Member#: 75378
1999 Forester
Well, the gauges are the autometer carbonfiber series but I don't really know abou the fiberglass, I know nothing about that.
stevepius is offline   Reply With Quote
New fabrication project- think motorized clock pod LCD brcewane Interior & Exterior Modification 89 03-09-2008 12:16 AM
FS:NJ - New, Genuine, Defi Center Triple Gauge Pod ushtang Private 'For Sale' Classifieds 2 12-01-2005 09:15 PM
FS: Brand NEW Autometer a-pillar triple gauge pod!!! aps2fast4u Private 'For Sale' Classifieds 3 04-19-2005 06:17 PM
my new ultra JDM coke/defi gauge pod. (custom made, only one in america, JDMM!) djcttb Member's Car Gallery 30 01-13-2005 10:45 AM
new to old A-pillar gauge pod swap.... SilverSubie WRX Forum Archive 0 02-21-2001 06:41 PM
