Old 06-28-2005, 09:58 PM   #1
b00st3d
Member#: 9891
2015 RC-F
Ultra White
Default Mystery Green Plug Under Driver Side Dash '05 STi
anyone know what this plug is and why it may be disconnected from the other side of the plug? i dont know if i kicked it loose by accident...
b00st3d is offline   Reply With Quote
Old 06-28-2005, 10:01 PM   #2
Davenow
Member#: 23676
that looks like this plug the cars are delivered with plugged in, and the techs are supposed to unplug it when prepping the car.
But thats usually on the passenger side. But that looks EXACTLY like that plug.
Old 06-28-2005, 10:07 PM   #3
eyehate
Member#: 10223
that is to put your car into test mode! us peoples with the accessport have to plug those two together and add one other somewhere else to re flash our ecu!... if you plug them in, and put the key to on, your car will cycle through radiator fan cycles and so on and so forth, and will drive very slowly. :-)
eyehate is offline   Reply With Quote
Old 06-28-2005, 10:12 PM   #4
ranger5oh
Member#: 77752
5Sti 2005 Sti
you also have one in the passenger side kick panel, both must be connected for diagnostic mode. If you buy an AP you will find this out quickly, which I reccommend buying
ranger5oh is offline   Reply With Quote
Old 06-28-2005, 10:51 PM   #5
b00st3d
Member#: 9891
2015 RC-F
Ultra White
awesome...thanks for the quick input everyone!
Old 07-06-2005, 01:44 AM   #6
03 Silver Bullet
Member#: 27222
2o1o Audi S4
Imola Yellow
that actually looks like the plug I had in the WRX. Disabled the plug and a wire to allow teh clutchless start.
Could be completely different on the 05s?
03 Silver Bullet is offline   Reply With Quote
Old 07-07-2005, 03:19 PM   #7
R4ND0M_AX3
Member#: 67483
2005 WRX STi
STi only needs the plug under driver side connected for AP base map flashing. Not even sure if there is one on the passenger side.
R4ND0M_AX3 is offline   Reply With Quote
06 wrx green plug under dash? hookedontronics Interior & Exterior Modification 3 07-20-2009 11:06 AM
Green plug under dash? snapperswrx Electrical & Lighting 2 08-06-2007 02:10 AM
Strange green plug under my dash makes a CEL CIATexan Electrical & Lighting 10 11-09-2005 10:21 AM
green plugs under steering wheel... happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-25-2004 04:33 PM
green plug under driver's side dash AustinTX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-07-2002 08:46 PM
