Old 06-29-2005, 12:35 AM   #1
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
Default car bucking and surging, o2 sensor? cel = p1137
On my way home from work on friday my rs started surging on the interstate. My radio started fading in and out and the car would hardly keep speed. i turned off the interstate, and at about 35mph or so, the car starting bucking like i dumped on the clutch on it. I pulled over, let it sit for a few minutes, then drove the next half mile home.
I didnt have a cel on? but i decided to check if there were codes anyway. I had a p1137, which wasnt in my book of codes, but I think it is some sort of front O2 sensor code. I then reset my ecu and my car has been fine.
However, knowing that these cars have problems with the 02 sensors, I went to subaru and bought a new front A/F sensor. The car is fine now and no more codes after driving it 100 miles.
Do you think the problem is the front o2/ A/F sensor? Anyone else have this problem?
ah, its a 2000 RS
imprzya is offline   Reply With Quote
Old 06-29-2005, 12:35 AM   #2
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
We also pulled the plugs after all this happened, they looked white, that means the car is also running lean. However, there are no misfire codes and I havent heard any knock.
Old 06-29-2005, 12:49 AM   #3
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i have no input other than: my front o2 sensor is out (p1130) when i had someone check it they also cleared it. it took 180 miles for the thing to come back on. so drive another 100 or so and see if it comes back.
svek is offline   Reply With Quote
Old 06-29-2005, 01:04 AM   #4
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
check your ignition coil pack. It seems a common enough failure and has those symptoms. There is a check procedure in the FSM.
-Rob
rob is offline   Reply With Quote
Old 06-29-2005, 01:05 AM   #5
mrpedal
Member#: 71361
2000 Impreza 2.5RS
FWIW...
Google says: P1137 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
that from a gm/buick car site: http://myweb.accessus.net/~090/dtcobd2p.html
This from another google, this time a subaru site: P1137 Front oxygen (A/F) sensor circuit range/performance problem
http://www.obd-codes.com/trouble_cod...obd2-codes.php
mrpedal is offline   Reply With Quote
Old 06-29-2005, 04:07 PM   #6
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
details on checking the coil:
emissions and the o2 sensor/cel wrxCerberusgsx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-08-2007 01:44 PM
emissions and the o2 sensor/cel wrxCerberusgsx Newbies & FAQs 1 09-01-2007 10:19 PM
FS: Subaru OEM Fender Plug and Downpipe o2 sensor CEL fix Tomass Engine/Power/Exhaust 3 07-16-2007 02:44 PM
FS: Subaru OEM Fender Plug and Downpipe o2 sensor CEL fix Tomass Suspension/Brakes/Handling 0 05-27-2007 04:35 PM
Rear O2 sensor CEL-Cincy guys need help! asthecrowflys Mid West Subaru Owners Club Forum -- MWSOC 2 12-30-2003 05:17 PM
