Old 08-07-2001, 08:20 PM   #1
Dan00RS
Member#: 1367
2000 Impreza 2.5RS
Blue Ridge Pearl
Unhappy HELP - Where the H-E-LL is the tranny drain plug and filler?????
OK, I'm changing the gear oil on my RS (5-spd) and I just finished the rear diff, but I cannot locate the !#$&*$% tranny oil drain and fill plugs. Any help??
Thanks in advance!!
Dan00RS is offline   Reply With Quote
Old 08-07-2001, 08:40 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The drain plug is right at the Y of the header, where the driver and passenger side manifolds come together. It's a big arse bolt, hard to miss. I recommend draining the tranny while the exhaust is fully cooled so you can wrap a plastic bag or something like that around that Y section. If you don't, you will get gear oil on the exhaust, and it'll stink as it cooks off the next few times you drive the car.
There is no fill "plug", you just fill it through the dipstick hole (which is just behind the engine on top of the tranny, passenger side). You'll probably need one of those funnels with the long, flexible hose coming off the bottom, and you may need to remove the air box to get good access to it.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-07-2001, 08:50 PM   #3
Dan00RS
Member#: 1367
2000 Impreza 2.5RS
Blue Ridge Pearl
Thanks Pat!!!!!!!!
Old 07-08-2005, 12:55 PM   #4
b16h22
Member#: 90824
2009 STI
Default full plug?
is there a bolt on the tranny of an 00 RS to unscrew that lets you know how much gear oil to put in? i've worked on other transmissions where this is the case. the oil spills out of this hole which is located a few inches above the drain plug. if not, about how much gear oil should it take? thanks for the help..
b16h22 is offline   Reply With Quote
Old 07-08-2005, 01:39 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
no there is not. You fill through the dipstick hole Like Pat explained. When you feel your getting close to the correct amount you remove the funnel and check it with the dipstick.
Tim Sanderson is offline   Reply With Quote
Size for Tranny drain plug and diff plug? sfwrx Transmission (AT/MT) & Driveline 11 09-16-2007 12:38 AM
Help! Found this piece of metal attached to the tranny drain plug. Pics! subysouth Transmission (AT/MT) & Driveline 46 07-24-2007 05:14 PM
Part Numbers for Differential and Auto Tranny Drain Plug Gaskets sj72 Service & Maintenance 5 03-23-2004 06:22 PM
Is the tranny drain plug 21mm RichinAZ Service & Maintenance 3 04-11-2003 06:10 PM
Need a pic where the tranny drain plug is BIG BEN Transmission (AT/MT) & Driveline 3 11-02-2002 02:22 AM
