Old 06-29-2005, 05:21 AM   #1
w chapman
Member#: 75673
Default Which Yr engines will replace a 1999 DOHC 2.5L
Just purchased a 1999 Outback Limited with terrible "death rattle" in the engine..a DOHC 2.5L.
As I shop for a replacement, I need to know which engines (year/Subaru model ??) are compatible to replace this engine.
I have a couple of Subaru engines.....a 99 2.2L and also a SOHC 2.5L from a 1999 Forester, but no DOHC 2.5L...love to put the SOHC 2.5L in...but I've heard there are a lot of differences/obstacles to this swap.....i.e would not be plug and play.
I'm a big fan of the early 2.2Ls ...and have put several into VW Vanagons..but not much experience with the the DOHC 2.5L. I know the DOHC 2.5L has a reputation for a lot of problems.
Any comments...tips...appreciated.
Anyone have a known good 2.5L FS ??
Warren Chapman
Founder/Moderator
SubaruVanagon Yahoo Group
Mill Valley, CA
w chapman is offline   Reply With Quote
Old 06-29-2005, 12:01 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The 97-99 Legacy GT and Outback will have the DOHC 2.5, though some later Outbacks have been known to have Phase II SOHC blocks. The 98 2.5RS was the only Impreza with the Phase I.
As for swapping in...i'll leave that to the "experts" Finding a way to get the Phase II SOHC engine in would be my vote.
DLC is offline   Reply With Quote
Old 06-29-2005, 12:38 PM   #3
ImprezaRallystyle
Member#: 48918
2006 Forester XT
1993 impreza RALLY
Smile
if i'm right the difference between dohc and sohc is in the motor heads. d stand for double cam and s for single cam. is the sound comming from the heads or more from piston and crank cuz twincam have heating heads problem and on the other side single cam have piston problem. i dont think you would have any major problem swapping maybe a few sensor that you will need to keep from the old motor like temp sensor but all the major one are the same ( crank sensor,cam sensor, fuel injector, coil, etc...)
if you want you can keep the short bloc from your dohc and fit the single head cam on, it will work good ) as long as you use the twincam head gasket.
any motor from 1996 late production till 1999 fits.
as long as they are ej25
ImprezaRallystyle is offline   Reply With Quote
Old 06-29-2005, 01:48 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Do what he said. That death rattle is most likely rod knock. Just pull the SOHC heads off of the Forester engine and use the block with your DOHC heads. Both the '99 Forester and '99 Outback should have phase II bottom ends. And IIRC, that Forester block should have an oil cooler attached to boot...
Old 06-29-2005, 02:33 PM   #5
w chapman
Member#: 75673
Default Death Rattle
The '99 2.5L currently in the Outback....sounds awful....like a big diesel....serious knocking...sometimes changes pitch/loudness...sometimes sounds minor, like a stuck hydraulic lifter...sometimes very loud...like a big diesel at idle.
I guess I could take my '99 SOHC apart for the shortblock.....but hate to dismantle a complete engine....that I paid a fiar amount for....not to mention all the labor involved.....still hoping to find a complete DOHC 2.5L or at least a good longblock.
If I find one, I'll probably replace the head gaskets, timing belt, and seals..for insurance.......are there new "preferred" headgaskets available....after all the history of hg problems ?
Warren C.
Old 06-29-2005, 04:50 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Well,
The DOHC heads don't have hydraulic lifters. They have solid buckets that you adjust lash with shims. If it really is the heads, either you have knocked a lobe off of a cam, or spit a shim out. Either one is not an easy fix. You could easily find out by removing the valve covers with the engine in the car and turning it over by hand. If there is something wrong with the heads, you will see.
OR, just maybe you have the timing off by a tooth. But my money is on the bottom end.
Beyond that, changing the heads from one engine to the other is pretty straightforward and easy. But if you are set on going shopping for a drop in replacment, a '97-99 DOHC Ej25 is the ticket...
WTB: H4-DOHC,2.5L, EJ255 engine for 05 Legacy GT michaeljgondek Private 'Wanted' Classifieds 7 05-19-2008 11:43 AM
Need DOHC 2.5L engine specs for final project t3hWIT Normally Aspirated Powertrain 10 04-27-2008 06:31 PM
phase 1 dohc 2.5l engine anothermbdusted Private 'Wanted' Classifieds 0 06-03-2007 12:44 AM
1998 DOHC 2.5L engine problem. what to do? YaZahX Normally Aspirated Powertrain 10 06-18-2003 01:10 AM
swapping out DOHC 2.5L engine for SOHC 2.5L engine 2.5GT Normally Aspirated Powertrain 2 11-14-2001 03:58 PM
