#1 |
Member#: 53815
Vehicle:2000 impreza 2.5 rs metallic red |
I will be replacing my head gaskets on my 2000 2.5rs this weekend and sence the heads, intake manafold and TB will be out I was going to do some port matching and genral cleaning up.
I was wondering who has port matched heads of simmular casting? I am worried about taking too much off and getting cracks thru to the water jacket. How much should i take off? Would I be able to port match the intake and exhaust with no issues?. Please some one let me know.. I would hate to take off too much and wreck my heads!.
#2 |
Member#: 48918
Vehicle:2006 Forester XT 1993 impreza RALLY |
use your gasket to determinate the maximum size of porting... place it over your heads use some spray pait and there you go. the same process can be done with the intake. this is the best way of not removing to much.
#3 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Don't waste your time or effort. The gains, if any will be minimal. 90% of the gains to be had with headwork is from working the valve seat.
Instead, spend a little extra money to get the thin .027 Cometic metal headgaskets and bump your CR to 11.4:1. That got me +/-15whp. You gains will be less if you don't have cams, but you will still see some gains... |
#4 |
Member#: 53815
sure, Ill throw on a set of those too.. I would just feel better reaming every thing out.
where can i get a set of thouse gaskets? |
#5 |
Member#: 53815
never mind axis has the line on em.
thax |
| Thread Tools | |
| Display Modes | |
| WTB: 2 SOHC 2.5 Longblocks (just heads, block and oil pan) | Tattoo Collector | MAIC Private Classifieds | 3 | 02-09-2006 01:28 PM |
| WTB: 2 SOHC 2.5 Longblocks (just heads, block and oil pan) | Tattoo Collector | Tri-State Area Private Classifieds | 0 | 02-07-2006 02:14 PM |
| WTB: 2 SOHC 2.5 Longblocks (just heads, block and oil pan) | Tattoo Collector | NESIC Private Classifieds | 0 | 02-07-2006 02:14 PM |
| Will a DOHC f2.5 intake manifold bolt up SOHC 2.5 heads | w chapman | Normally Aspirated Powertrain | 9 | 10-11-2005 10:24 PM |
| EJ22T w/ SOHC 2.5 heads | cjfike | Normally Aspirated Powertrain | 11 | 10-01-2005 03:21 PM |
