Old 06-29-2005, 11:39 AM   #1
Texas Red Rex
Member#: 88655
04 WRX
SR Red
Lightbulb Cluster Light Pins Found, Easy Film Removeal
I figured out that the second and third pins from the right on the 10 pin connector light up the cluster lights with 12vdc applied. If you happen to have a DC power supply laying around you can light the lights outside the car which makes checking your progress removing thr green film easier. Also using high grade isopropal alchohol will take the green film off easier. Find q-tips with wooden handles so you can apply enough force to rub the film off. Roughing up the film helps remove it.
Texas Red Rex is offline   Reply With Quote
Mud Flaps easy to remove and put on? Dragicon Newbies & FAQs 4 11-11-2006 04:21 PM
Cluster re-pinning... Electrical Guru's needed FederalAuditor Interior & Exterior Modification 1 04-19-2005 04:59 PM
Anybody found easy fix for squishy XT brakes? MyOtherCarIsASubaru Brakes, Steering & Suspension 5 10-30-2003 09:41 PM
Vinyl electrical tape - how easy to remove? chkltcow Interior & Exterior Modification 1 05-01-2003 02:20 PM
