Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 06-29-2005, 02:42 PM   #1
ludecrous
Member#: 19376
2003 03 WRX Wagon
Default Best way to run wire (pic inside)
What's the best way to wire from A to B in a WRX?
I wish to wire a +12v, a ground and another wire for a signal.
Is there any way to use the harness which already exists in C ?
Note: I do not wish to direct tap off the map lights as I would like a switch at position A.
I have not pulled apart behind the glove box so I don't know what wires are available there.
Thanks
oh, please forgive the crappyness of the sketch, I did it because it explains the situation pretty well.
ludecrous is offline   Reply With Quote
Old 06-29-2005, 03:43 PM   #2
RS Paul
Member#: 87520
You don't say what year car you have but 2004s are wired for
a sunroof (one wire, green with black stripe <IGN 12v>) and
a "spot light", whatever that is, (two wires, black <ground> and
blue with red stripe <battery 12v>).
The spot light wires could give you your power and ground
and the sunroof wire (if you don't have a sunroof) could provide
the signal wire if you can figure out where to disconnect it from
the power window relay without disabling your windows.
All three wires look to be in the area you're interested in.
RS Paul is offline   Reply With Quote
Old 06-29-2005, 04:13 PM   #3
WRXRgr
Member#: 54942
2004 WRX
You've already got +12V, ground up in B, for the map lites...how much amperage are you looking for?
WRXRgr is offline   Reply With Quote
Old 06-29-2005, 04:18 PM   #4
ludecrous
Member#: 19376
2003 03 WRX Wagon
I have a 2003 Wagon. I believe the auto dimming mirror harness is up there somewhere with 3 wires (I don't have an Auto dim mirror) but I would not know where to diconnect it as you were saying.
In position A I would like to put a on/off switch for the power to B (radar detector)
Old 06-29-2005, 04:39 PM   #5
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I put an on/off switch for my radar detector in one of the spots to the left of the fog light and cruise control switches on the dash.
I simply took a switch I had at work (for a round receptacle with square push button), took one of the blank inserts in the dash and drilled a hole to mount the switch in the blank insert.
I ran the power wire for the radard detector to the cigarette lighter (as my car did not come with one, just a fake plastic piece), and brought the ground wire to the switch. The other leg of the switch, I put another wire and grounded it to a piece of metal under the dash.
As far as routing the wires, I went from under the dash on the drivers side, up through the A-pillar, underneath the headliner, and finally to the radar detector. If you have a Valentine1 the telephone looking wire going from the adapter to the VI is long enough.
coyote73176 is offline   Reply With Quote
Old 06-29-2005, 05:15 PM   #6
ludecrous
Member#: 19376
2003 03 WRX Wagon
Coyote, I'm looking to put an on off switch and a remote display in the center console near the mirror controls. I was hoping to run up the PASSENGER A pillar since there are already wire harness in there.
Old 06-29-2005, 05:16 PM   #7
ludecrous
Member#: 19376
2003 03 WRX Wagon
This is the remote display I am looking to put in the center console from an Escort 8500
Old 06-29-2005, 05:30 PM   #8
ludecrous
Member#: 19376
2003 03 WRX Wagon
Trick is that I don't know how/ the best way to run the wires to point B....
Can I run behind glove box and up A pillar passenger side ?
Can I tap into wire harness that runs up passenger side?
Dos the harness run close to the stereo area, so I could tap into it there ?
Any Ideas ?
Old 06-30-2005, 10:53 AM   #9
ludecrous
Member#: 19376
2003 03 WRX Wagon
bump up
Old 06-30-2005, 10:53 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice sketch.
Best way to run a Cat-5 from one side of a wall to the other? Hazdaz Off-Topic 49 06-16-2009 07:15 PM
Installing AEM UEGO in a single pod (cup) - best way to hide wiring? txl146 Electrical & Lighting 0 01-07-2008 12:12 AM
Best way to run Satellite antenna in wagon? Reat mount mummer43 Car Audio, Video & Security 7 10-02-2006 03:00 PM
Best way to run amuck??? MK19_ Off-Topic 13 03-29-2006 01:00 PM
Best way to route wires on column mount boost gauge? drees Interior & Exterior Modification 11 05-08-2003 06:24 PM
