Old 06-29-2005, 02:51 PM   #1
wrxwhip
Member#: 80343
1993 T67 Supra
Graphite
Default Turbo Timer Help
Hello,
I recently got a Blitz FATT DCII turbo timer and harness. I tried installing it today on my 2005 wrx. I followed the instructions on various sites. I ran into a problem though. It seems that the turbo timer is not turning on, I think there is no power. Also, I did all the other steps such as splicing into the Keyless Entry, the dark green wire with the black stripe. Then I spliced the purple wire from the TT to the green wire connected to the E-Brake. The one part I didn't do is cut the grey wire near the security unit by the ebrake. I cant find a grey wire in that area. There is a group of 3 wires, a white one, black one, and red one. The white one has a few grey boxes on it. I am not sure which one of those wires I am supposed to cut and/or splice into. Also, there is a grey wire that is part of the harness itself that is not connected to anything. Also there are two black wires that are part of the harness that are not connected. The one of the two black wires is spliced into the Keyless Entry (the green wire with the black stripe) Please let me know if I did anything wrong or if I need to do something to gain power for the turbo timer. Also, when I started the car it started fine, its just the Turbo Timer did not turn on. Thanks.
Cliff
wrxwhip is offline   Reply With Quote
Old 06-29-2005, 04:52 PM   #2
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
When I installed my TT (same one you have) I grounded to the two black wires that were on the TT harness. I didn't have to tap anything in with the keyless entry (but this may be because I don't have an alarm). As far as tapping the line into the e-brake, I didn't bother with this either because I wasn't sure which wire it was (didn't have a voltmeter handy when I did the install).
Sorry if this doesn't help much.
I just double checked the install instructions (and of course noticed I have the FATT DC, not the DCII).
My harness had (2) black wires ---> I grounded both
The TT had a purple wire that was supposed to be connected to the e-brake, but I just grounded that one as well.
It may also be different with the 05's because of the immobilizer.
coyote73176 is offline   Reply With Quote
Razo RE40 Turbo Timer Help Needed! ginjaninja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-12-2002 07:37 PM
hks turbo timer help Fast turbo 21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-14-2002 01:11 PM
Blitz turbo timer help Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-16-2002 09:03 PM
Erratic turbo timer, Help! linus011 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-25-2002 10:45 PM
Slight problem with my Turbo timer - help! djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-26-2001 12:06 PM
