Mid Atlantic Impreza Club
Old 06-29-2005, 10:29 PM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Default Playing with ideas. Anyone have an 00 or 01 2.5rs motor for sale with < 100k on it?
Looking for a 2.5L in good shape with less than 100k on it as it would probably be cheaper for me to clean that up and play with it than it will be to get the headgaskets done in my motor.
Let me know.
Thanks,
-- Dave
AcquaCow is offline   Reply With Quote
Old 06-29-2005, 11:15 PM   #2
jmj1112
Member#: 57051
02 WRX
o oh..........lol
jmj1112 is offline   Reply With Quote
Old 06-29-2005, 11:31 PM   #3
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I have a present for you Jay...hold that thought for a moment.
[Edit: made a new thread]
-- Dave
Old 06-29-2005, 11:32 PM   #4
Seeing StaRS
Member#: 5294
Dave,
I take it then that your original motor had the headgasket go up on you too. Whats your mileage? did you have the coolant reconditioner additive tsb performed on your cooling system? If so you may have a warrantable claim with SOA.
joe
Seeing StaRS is offline   Reply With Quote
Old 06-29-2005, 11:53 PM   #5
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I'm at 77,3XX right now and the cooling side of the headgasket is fine. Conditioner was added at 55k. Mine's leaking about a quart of oil every 2 weeks from the oil return lines at the bottom of the block. The headgasket is supposed to keep that oil in there, but it's not and Subaru says that's not a warrantable condition for headgasket replacement. The headgasket MUST be leaking coolant for that to apply.
I was looking at repair options and the cheapest is $600-700. To have a dealer do it it'll cost me about $1500.
I figure I can pick up a used EJ25 for a few hundred dollars, do the headgaskets on it myself AND get the cams reground for sub $700...
Then I'd fix the gaskets on this motor and turn that around for someone else. Other than the leaky gasket, the motor is in perfect shape.
I'd do the whole WRX swap thing, but I don't have the down time to complete it right now. I don't have a second car and I don't have a garage, so any swaps I do have to be rather simple. I figure dropping a fresh EJ25 in place of my current one is the fastest/cheapest/best option.
-- Dave
Old 06-30-2005, 12:30 AM   #6
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
or buy a lgt
psyber_0ptix is offline   Reply With Quote
Old 06-30-2005, 01:10 AM   #7
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Originally Posted by psyber_0ptix
or buy a lgt
You'll do anything to get at my 4-pots won't you
Old 06-30-2005, 07:52 AM   #8
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
-- Dave
How much would it cost to rent a car for the downtime of the WRX swap? If you're willing to do it, it might not be that much more expensive.
Old 06-30-2005, 08:07 AM   #9
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Not that much more expensive?
I'm looking at $800 max to fix up an EJ25, or around $2k to wrx swap...
That's a pretty big difference.
-- Dave
Old 06-30-2005, 08:11 AM   #10
Butt Dyno
Member#: 17301
is the "dark side"
-- Dave
You said that downtime / second car / garage were the main problems with a WRX swap.
At least some downtime will happen either way (unless you just give the car to Andrew or something)
Rental solves the "second car" problem
And you have the garage problem whichever motor you swap
what am I saying.. Dave with b00st.. head for the hills!
Old 06-30-2005, 08:15 AM   #11
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Dave:
1: Pour some coolant into your oil.
2: Drive to shop.
3: ????
4: Gasket!
5: Replacing your HGs (though I'm very hesitant to suggest this because I have a feeling it means my garage becomes your new home) is easier than replacing the motor. I helped Tom replace his DOHC HGs with the engine still in the car, in theory your SOHC is half the work...
rogue is offline   Reply With Quote
Old 06-30-2005, 08:50 AM   #12
BryanH
Member#: 993
If you want to do the HG's I'll help too. Or you you can do it out at my place over a long weekend. I have every other friday off.
BryanH is offline   Reply With Quote
Old 06-30-2005, 08:57 AM   #13
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Originally Posted by rogue
Dave:
2: Drive to shop.
3: ????
4: Gasket!
Well, we know he likes your couch at the very least. Just toss a forty down the stairs every night and lock the door to the upstairs and you'll be fine.
Dave, maybe take a look at the public auto auctions down and around the area. Pick up a cheap beater that will get you around, put RS on timeout and figure things out. I'm sure you could find a early 90's Audi quatro for cheap. I have a few links at home that I can pass on to you if you want.
AJ
AJ711 is offline   Reply With Quote
Old 06-30-2005, 09:00 AM   #14
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
I know of some cheap DSM's for sale.... Come to the dark side!!!
slim speedy is offline   Reply With Quote
Old 06-30-2005, 09:26 AM   #15
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
The Quattros I've seen have always been $$$. No need to get an AWD beater, just get some FWD POS
Old 06-30-2005, 09:27 AM   #16
Butt Dyno
Member#: 17301
is the "dark side"
Or a Miata
*ducks*
Old 06-30-2005, 09:47 AM   #17
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
If you can get it done for $700 and it can be done in 1 day, just do it. If you figure time = money, and you value your time, it's the cheapest way to go. It's going to take a LOT of time to find an engine, get it, put in the new head gaskets, take your engine out, put the new engine in, and then troubleshoot why it doesn't run (trust me, it won't run first try).
Old 06-30-2005, 09:51 AM   #18
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Or a Miata
*ducks*
I said FWD POS, not "girl car."
And I agree with Tim on the swap, it's going to be almost as much $$ and extra heartache. $700 ain't bad.
Swapping your HGs with the engine in the car IS possible, as Tom can attest... but it took him two weeks working many hours a night after work to get it done, even with some help.
Old 06-30-2005, 10:01 AM   #19
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Well the thing with having a spare motor on the side is that I can do all of the work on it while I keep my car running. Then we just pick a weekend and take a few hours to swap the motors out.
Otherwise I start piecing together a wrx motor and building it on a table as well and once it's all assembled, swap the motors and then figure out 15 hours of wiring =P
-- Dave
Old 06-30-2005, 10:12 AM   #20
TurbojonLS
Member#: 38772
2 Cars, No Bling
... Then we just pick a weekend and take a few hours to swap the motors out.
I've never swapped an engine in/on anything, but I'm thinking it will take more than "a few hours".
TurbojonLS is offline   Reply With Quote
Old 06-30-2005, 10:14 AM   #21
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
People keep telling me that it only takes 2 hours to get the motor out of the car...shouldn't take much more than that to put it back in...esp while everyone's fresh.
The tech's at Paul Brother's pulled a motor in 45 mins with air tools...
-- Dave
Old 06-30-2005, 10:14 AM   #22
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
-- Dave
Y...ea...h....
Where is this "table" you speak of, Mr. Lives On The Third Floor In An Apartment With No Elevator?
I've carried EJ motors, I can move them about 4 feet by hand with help before my bones give out.
Old 06-30-2005, 10:14 AM   #23
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
-- Dave
And slim speedy can swap an entire suspension alone in 20 minutes
Old 06-30-2005, 10:15 AM   #24
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
ZING!
Old 06-30-2005, 10:15 AM   #25
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Y...ea...h....
Yeah, but you also can't carry 2 bags of gravel.
WTB 00 or 01 2.5rs digitalphotographer Private 'Wanted' Classifieds 0 03-06-2008 09:04 AM
00 or 01 2.5 rs for project car.... ASHLEELOVE Private 'Wanted' Classifieds 0 05-17-2006 08:52 PM
Gauging Interest. 99 2.5RS motor for sale soon 992.5RS Private 'For Sale' Classifieds 4 02-10-2005 04:52 PM
01 2.5RS Coupe for sale johnb Private 'For Sale' Classifieds 11 10-04-2003 04:51 PM
