Old 06-30-2005, 04:01 AM   #1
pico
Member#: 5254
01 WRX
Default Stupid light bulb......
My battery was drained last week, I took out the battery and let autozone recharge it for me. Then i measured the reisistance between the 2 cables and it show 3.7ohm!!! I checked all the fuse and they're all fine and after 2hrs of peek and poke finally i find out that my trunk light bulb was shorted!! I always thought light bulb will be opened rather than shorted when they goes bad.....
pico is offline   Reply With Quote
Old 06-30-2005, 09:04 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
That is actually a normal resistance reading for a light bulb. The problem isn't the bulb itself, but that it is connected when the trunk is closed. Your problem actually lies with the trunk light switch, rather than the bulb. The switch is either defective or not adjusted properly. You can confirm this by looking through the rear seat pass-through when the trunk is closed, if the light is still on you'll see it. If it is proceed to either adjust or replace the switch.
Old 06-30-2005, 03:12 PM   #3
pico
Member#: 5254
01 WRX
thats true......... but isn't 3.7ohm kinda low??? which means it draws >3 amps when its on..... thats about 40W?!
Old 06-30-2005, 04:21 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The resistance of the filament increases when it heats up. So did you check your switch?
Old 06-30-2005, 04:34 PM   #5
avk
Member#: 17252
'06 WX8
59E
The resistance goes up some 10 times, so the power will be in 5W range which is about right.
avk is offline   Reply With Quote
Old 06-30-2005, 09:41 PM   #6
pico
Member#: 5254
01 WRX
ic, I haven't has time to check it yet. but let say if the switch is bad, which means i has it on for a few days, will it drain my battery out? or do u think i have some other stuff thats drawing power as well??? I guess the light buld is smart and i'm the stupid one...
Old 06-30-2005, 09:49 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Yes a stuck-on trunk light will drain the battery if left alone for a few days. Exactly how long it will take depends on the battery condition and state of charge(may not be too good if it's been discharged already). If you can't get to it right away, just take the bulb out.
Another sign it's been on is if you open the trunk to pull the bulb, and it feels very hot from being on a long time.
Old 07-01-2005, 04:16 AM   #8
John UK
Member#: 81042
2000 5 door turbo
It's easy to check if the light is on all the time.
Climb into the trunk and shut the lid.
Just make sure a (good) friend is there to let you out again.
John
John UK is offline   Reply With Quote
Old 07-01-2005, 06:14 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Not necessary with the pass-through.
Old 07-01-2005, 11:10 AM   #10
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
can't hellp but think of the refrigerator.
Climb into the trunk and shut the lid. Just make sure a (good) friend is there to let you out again.
John
also there is an emergency trunk release in the trunk. and it glows in the dark.
RR
Rapid_Roo is offline   Reply With Quote
Old 07-01-2005, 01:13 PM   #11
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
yep.....scariest thing is when it doesnt work though.....my fat ass cant fit through the pass through
ATX25RS is offline   Reply With Quote
Trying to find absolute brightest dome light bulb---how to test bulb? lennyTR Electrical & Lighting 54 03-13-2009 02:56 PM
local shops for yellow h3 bulbs and light bulb condoms (for dashboard lights) ex_boyometric Vancouver Impreza Club Forum -- VIC 8 01-17-2008 04:04 PM
Stupid little bulb in the headlights of the 06 impreza SpaceMonkey0453 Electrical & Lighting 8 09-20-2006 03:22 PM
quick question about buying new turn signal bulbs/ parking light bulbs SoareS Newbies & FAQs 1 10-08-2005 07:43 PM
Blinker bulbs and reverse light bulbs? Jay04WRX Electrical & Lighting 4 10-09-2004 08:06 PM
Message Board Statistics All times are GMT -4. The time now is 10:42 PM.
