Old 06-30-2005, 08:00 AM   #1
cudaeh
Member#: 53815
2000 impreza 2.5 rs
metallic red
Default do i need to replace the head bolts?
Well I picked up all my gaskets for the head gasket replacement, $171 worth. I mentioned to my friend all the stuff I bought and he read me the riot act because I said I didn't buy new head bolts. He said that when ever you take your heads off you sould replace the bolts. The theory he said was that when ever you torque a bolt down it stretches the bolt, when you take it out the bolt is still streched. I asked my dad (old school muscle guy) and he said that that was the case with corvair bolts back in the day because the bolts they used stock were too thin.
My question is have things changed that much between my dads time and mine?
Do I need to replace my headbolts or is that just paranoia?
cudaeh is offline   Reply With Quote
Old 06-30-2005, 10:52 AM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
YES You do do needto replace them. Buty do a search because awhile back there was a discussion on wheteher or not you had to. But froma mechanics point of view. ie...me. I would.
Russell Rogers is offline   Reply With Quote
Old 06-30-2005, 11:00 AM   #3
ImprezaRallystyle
Member#: 48918
2006 Forester XT
1993 impreza RALLY
not that i want to argu with you roger but at my local subaru dealer, my mecanic did over 75 motor job last year and he never replace the head bolt by new one.
Even in my race car he put back the original head bolt.
ImprezaRallystyle is offline   Reply With Quote
Old 06-30-2005, 01:03 PM   #4
cudaeh
Member#: 53815
2000 impreza 2.5 rs
metallic red
good enough for me
thanx
Old 06-30-2005, 01:42 PM   #5
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
I didn't replace them when I did the head job on a 2001 2.5 engine. That was well over 5k ago. No problems as of yet. If you do a search, you'll find reports of people re-using the bolts as much as 7 times! with no problems, I might add.
EcksJay is offline   Reply With Quote
Old 06-30-2005, 04:41 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Subaru doesn't use torque-to-yeild bolts for the heads.
You may reuse them...
Jay Storm
Old 06-30-2005, 09:12 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya, I was looking at my fsm after I read this this morning and normally if a piece or part needs to be replaced it will have a black star next to it. The head bolts did not have this black star so I would have to agree that they do not need to be replaced.
My fsm's are for 2000 model year impreza.
Tim Sanderson is offline   Reply With Quote
Old 07-01-2005, 12:10 PM   #8
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Exclamation They do to use tq to yield bolts.
I've worked as a tech for an auto dealership. All dealership techs are NOT master techs. I've seen a tech w/ 20+ yrs. exp. put a headgasket on backwards. They are not that expensive seeing that you spent WAY too much for all those gaskets. I rebuilt an entire ej25 motor and didn't spend over $100 for all the gaskets, seals, and new head bolts.
Just get new bolts, It can't hurt in the long run.
John2.5RS is offline   Reply With Quote
Old 07-01-2005, 12:40 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Don't waste your money on headbolts. Reusing them is totally fine. I have reused them on every EJ engine I have ever put back together (5 in the last year) with no problems. Give a call to Cobb, and they will tell you the same thing. As has been mentioned, just because a guy is a tech or even a master tech, doesn't mean that he is an expert, especially if he is a GM tech working on a Subaru. Storm has it right...
I was expecting headgasket issues, do i need to replace the radiator? AndyRoo Service & Maintenance 9 01-13-2009 11:49 AM
95 Legacy, zero clearance motor? do I NEED to replace the timing belt? IllNastyImpreza Service & Maintenance 5 07-13-2007 12:16 AM
Replacing stock downpipe - what bolts do I need to replace the spring bolts? ImportVenom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-22-2004 01:33 AM
Do I need to replace the studs/bolts? Ft_Laud_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-12-2003 10:22 PM
do I REALLY need to replace the flywheel? racerwad Transmission (AT/MT) & Driveline 8 11-01-2001 08:06 PM
