#1 |
Member#: 71032
Vehicle:2003 WRX World Rally Blue |
I'm trying to make a controller to spray water at the IC when the intake air temp (post intercooler) reaches above a set limit. What temperature range would you expect the air to be at? What sensor should I use. Thanks.
#2 |
Member#: 71032
Bump.
#3 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
You could probably just use a GM Intake Air Temp sensor. And depending on how good of an intercooler you are using will determine when its heat soaked and you should start spraying water. If i was to take a guess, anything over 150 degrees. about double atmospheric temperature depending on where you live. If you set it too low it'll be spraying water all the time. And too high it'll never spray. So you'll just have to experiment with it
| Thread Tools | |
| Display Modes | |
| Maf sensor for intake | Corpuz04 | MAIC Private Classifieds | 0 | 04-14-2010 04:06 PM |
| air intake/air flow sensor | legacytuner671 | Legacy Forum | 25 | 11-30-2005 12:57 AM |
| AEM cold air intake + MAF sensor for sale | ZapZilla | Private 'For Sale' Classifieds | 6 | 02-12-2004 10:30 PM |
| Intake Air Temperature Sensor | PimpinRex | Newbies & FAQs | 2 | 08-14-2002 05:25 PM |
| Is 150 microns enough for intake air filtration? | scoobyrex | Factory 2.0L Turbo Powertrain | 5 | 07-12-2002 06:22 PM |
