Old 06-30-2005, 02:15 PM   #1
Propaganda
Member#: 85116
2007 Forester XT
CGM
Default Where is PCV valve on 2002 WRX?
Where is PCV valve on 2002 WRX? I'm trying to do the Seafoam treatment, but I can't seem to locate it its on the intake manifold? If anyone has pictures that would be greatly appreciated! Thanks
Propaganda is offline   Reply With Quote
Old 06-30-2005, 02:35 PM   #2
pityr
Member#: 31719
pityr is offline   Reply With Quote
Old 06-30-2005, 03:17 PM   #3
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
I think it's hiding underneath the IC.
eltrouble is offline   Reply With Quote
Old 06-30-2005, 03:45 PM   #4
VSG
Member#: 19435
You have to take off the intercooler, and it will be underneath the throttle-body.
It's a good idea to disconnect the hose going to the blow-off (bypass?) valve. Bend it it underneath that smaller hose (towards the passenger side). I've found that is the easiest way to get to it. The hardest part was trying to get the intercooler back on. Huge pain!
By the way,
what's the seafoam treatment?
VSG is offline   Reply With Quote
Old 06-30-2005, 03:51 PM   #5
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
it removes deposits through the use of vaporization. You put it in your PCV, oil, and gas. Nobody really knows if it works or not, but the big white clouds of smoke is entertaining. And it's only like $5, and it takes forever to use it all up.
Old 06-30-2005, 08:36 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Dont use the PCV as it's a PITA to get to. Take the vacuum hose off of your brake booster (AKA master cylinder) on the drivers side rear of the engine compartment and use that. I've done it many times to many Subarus and it works well.
<------Sea Foams to be an asshat as opposed to it's "cleaning properties"
Old 07-01-2005, 12:40 AM   #7
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Wouldn't the vacuum line on the BOV also work? I figured that would be a lot easier to get to.
Old 07-01-2005, 01:15 AM   #8
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
the only hard part is getting the intercooler back on. that plastic doesnt give. but its not too hard. its a 19mm, just do it!
fantabulous is offline   Reply With Quote
Old 07-01-2005, 01:46 PM   #9
Propaganda
Member#: 85116
2007 Forester XT
CGM
Thanks for the replies! I used the vacuum line on the BOV although I have a 100% vent the top part of the BOV still worked /shrug. Did the seafoam treatment and MAN was there lots of smoke. I might just be a mental thing but I think it works. For those who don't know what Seafoam is should use search comes up with tons of topics about it! But a short breakdown is it cleans up carbon build up from cars running to rich IE. SUBARUS
Where is ECU located on '02 WRX??? SJwrx Newbies & FAQs 7 06-01-2013 04:16 PM
OK, WHERE THE HELL is the PCV Valve on a 2006-07 WRX? joserpm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-18-2009 06:36 PM
Where is the PCV Valve for 05 wrx? strictlyJDM Newbies & FAQs 7 05-01-2009 03:45 PM
Where is the PCV valve for 2004 WRX CoolRex Service & Maintenance 22 01-11-2007 09:08 PM
('93-'01) Where is the PCV Valve on a EJ18? SubaruImpreza_power Impreza Forum 3 07-11-2003 03:22 PM
