Old 06-30-2005, 11:10 PM   #1
porscharu
Member#: 90319
Default newby with strange ej25 problem
hello, my name is scott, i will tell you my story then the problem. i knwo this is a legacy forum but the motor is from a legacy so it does fit here some what
first off i have a 75 porsche 914, that i stuck in a 98 ej25 na motor. the 914 was a aircooled car that i put the radiator in the engine bay in front of the motor. the car is a mid engine car so the radiator is in the middle of the car. i kept the stock obd2 ecu and wiring, the wiring was trimmed down to fit and elimanate all the wiring i did not need. the car basicly runs with out any major trouble codes. i also flipped the intake around to fit the engine bay better, when i flipped the intake i had to relocate the alt to where the ac pump was.
the problem i am having is nuts, the alt died on me, it charges but after a few mins of driving it starts to lock up for a split second every second. this stopping makes the car feel like it is going to shake apart. so today i picked up a junk yard alt, and when i installed it, it runs like crap. if i disconnect the wire for the alt light on the dash, which also works with the exciter in the alt it runs fine, but only on the battery. do i try a third alt
TIA
scott
porscharu is offline   Reply With Quote
Old 07-01-2005, 12:39 PM   #2
98_soobie
Member#: 17071
mmm.... is everything lined up perfectly... maybe you need a new alt... not a used one... just an idea
98_soobie is offline   Reply With Quote
Old 07-01-2005, 12:54 PM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
scott
do you mean the intake piping? I hope you don't mean the manifold. I'd second the idea that the alt. is not lined up correctly. I'd put it back and re-route the intake piping.
iamrazor is offline   Reply With Quote
Old 07-01-2005, 06:42 PM   #4
porscharu
Member#: 90319
yes i do mean the intake manifold, i had to disconnect and reloacte a few items like the egr, the IAC , etc]
the alt is still on the stock bracket it is just rotated 180 degrees into the ac location, it is just up side down. the stock bracket just needed 2 cuts to get it to fit, then i made a support off of the old ac mounting holes to hold the other side of the alt up.
i have pics but cant post a link or pics here
scott
Old 07-01-2005, 07:54 PM   #5
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Have you posted this problem in the Conversions forum? There are some other people w/ Porsche conversions there that might have the expertise to help you out.
jey is offline   Reply With Quote
Old 07-01-2005, 07:58 PM   #6
porscharu
Member#: 90319
idid not know there was one but this is not really a conversion problem it is an alt problem but i will go there too
scott
Newbie with Heater Fan Problem bbwingz Service & Maintenance 1 10-13-2009 08:54 PM
Newbie with a Pulling Problem Mitch54 Newbies & FAQs 7 06-23-2009 04:32 PM
This thread is for hybrids with strange questions/problems... Drink Built Motor Discussion 2 12-08-2006 04:27 PM
Strange boost problem with a strange dealer diagnosis. Help? Computergeek24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-09-2006 12:34 PM
strange skipping problem - anyone dealt with Eclipse before? superhero Car Audio, Video & Security 3 05-16-2004 09:41 PM
