Old 07-01-2005, 12:21 PM   #1
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Question Anyone w/ fuel rail mod issues?
I was curious to see if anyone's running the fuel rail mod and if anyone notice a difference as far as performance, MPG, issues?
John2.5RS is offline   Reply With Quote
Old 07-01-2005, 07:29 PM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
which Mod. Parallel fuel rails? If thats the case no. but i have also tuned for it.
Russell Rogers is offline   Reply With Quote
Old 07-03-2005, 08:42 AM   #3
John2.5RS
Member#: 1140
'13 F150 Ecoboost
Default Yes.
Yes I mean the Parallel fuel rails. How did you tune for it? does it run richer?
Old 07-07-2005, 01:15 AM   #4
alter.ego
Member#: 82466
Red
bump!
alter.ego is offline   Reply With Quote
Old 07-13-2005, 10:47 AM   #5
John2.5RS
Member#: 1140
'13 F150 Ecoboost
Default ttt
bump.
Old 07-13-2005, 11:26 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
This thread is dead because none of the NA guys bother to mess with their fuel rails. Until you are well over 250hp, the stock fuel system, injectors, rails and all, are totally adequate...
Old 07-13-2005, 11:35 AM   #7
John2.5RS
Member#: 1140
'13 F150 Ecoboost
News Your wrong, 'cuz I did
Well, I did it when I put the turbo on but have removed the turbo(for now). I didn't see any reason to pull the intake manifold to return to stock see as I will be installing the turbo once I fix some other issues i'm having with the suspension & brakes. I was just seeing if anyone else had done it. I guess not.
fuel rail install issue rjrutzky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-15-2005 03:35 AM
anyone done the parallel fuel rail mod? brazymstrp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-01-2004 02:29 PM
Rigoli's hacked stock fuel rail mod??? Wombat North Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-01-2002 08:20 PM
Fuel Rail mod? amelnikov Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 48 02-08-2002 03:09 PM
Parallel Fuel Rail Mod Queston Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 26 01-27-2002 11:59 AM
