Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 08-08-2001, 04:51 AM   #1
jacklock
Member#: 5486
Question Blitz Dual TT question
Is anyone using the Blitz Dual Turbo Timer pictured here:
I was wondering whether or not the Boost Guage is reliable. And does it come with everything I need (ie rubber hose, T segment, etc) to install?
Any advice would be greatly appreciated. Thanks!
-jack
jacklock is offline   Reply With Quote
Old 08-08-2001, 05:05 AM   #2
bluemax
Member#: 6657
Can't see the picture but the Blitz TT comes with everything you need. I would recomend running the boost line away for high heat source. Also get the HKS TT wiring harness, it makes the installation much easier and cleaner. As far as the boost guage accuracy, I don't really know...I peak once at 1.09 (measured in kg something). Most of the time it's in the 0.9X range.
if you need installation instructions, you can find it with a search here at I-club.
good luck
bluemax is offline   Reply With Quote
Old 11-05-2001, 11:00 AM   #3
AltF8
Member#: 9376
2002 WRX Sedan 5MT
World Rally Blue Pearl
Just installed mine...I'm reading .69 peak. That's in hkPA, or hundreds of kPA.
I'm getting a crappy reading because I tapped the wrong line though...duh...
AltF8 is offline   Reply With Quote
Old 11-08-2001, 09:21 AM   #4
AltF8
Member#: 9376
2002 WRX Sedan 5MT
Re-tapped the line into the BOV line.
Now, I'm peaking at 101kPA, or about 14.5 psi.
To get your psi, multiply the reading on your Blitz by 14.5. That will compensate for the hundreds reading that the gauge gives you.
Blitz dual TT with keyless entry? YaZahX General Community 12 07-07-2005 03:12 PM
Help...mouting that damn Blitz Dual TT w/ boost gauge!!! Jimmy S. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-02-2001 01:21 AM
Blitz Dual TT install questions WRX Power Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-06-2001 06:34 PM
Blitz Dual TT or MSTT? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-22-2001 11:49 AM
Blitz Dual TT questions? jjameson New England Impreza Club Forum -- NESIC 0 05-01-2001 08:28 AM
