Old 07-01-2005, 07:14 PM   #1
Chris1530
Member#: 90362
Unhappy Umm Something is Wrong
Have nowhere else to turn. I have a Legacy, 2.2 with used engine, starts runs ok, not great. Will not Idle, when Rpms drop near 1500, feels like it is ging to stall, anything below that and it sounds like it is running on 2 cylinders, replaced MAFS, New Plugs, Timing Belt Lines up proper, dont feel like it has any power either though out the Rmp range, Any one have this kinda problem or simmler. Please can Somebody Help Me
Chris1530 is offline   Reply With Quote
Old 07-01-2005, 07:23 PM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
check the PCV valve. Then check your coil pack. Then make sure there is fuek pressure at idle.
Russell Rogers is offline   Reply With Quote
Old 07-14-2005, 04:22 PM   #3
jibco
Member#: 43598
06 WRX sedan
Coil pack and plug wires?
jibco is offline   Reply With Quote
Old 07-14-2005, 05:45 PM   #4
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
http://bbs.legacycentral.org
I'm sure they can give you some help / advice there if nasioc doesnt work out for you.
2.5RSMatt is offline   Reply With Quote
Old 07-15-2005, 12:08 PM   #5
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
Yeah legacy central is a good source for information, just try to research what you are asking about a little or they might lock your thread. Thats what they did to me.
Millencolin! is offline   Reply With Quote
Old 07-15-2005, 12:27 PM   #6
protocall
Member#: 38348
temp sensor?? Mine went once and it revved reeeeeeaaal low like you are saying and I had no power. mechanic replaced the sensor (for free!) and ran like a champ (i have a 99 2.5rs though)
protocall is offline   Reply With Quote
Old 07-15-2005, 03:40 PM   #7
kattz
Member#: 39032
2006 Forester LLBean
Grnt Red/Ttnm Silver
Sounds exactly like a problem I had with a 77 VW Scirocco. Check the compression on all four cyls. Also, take a dollar bill or a pice of paper, and with the engine running at idle, place it loosely over your exhaust while holding it firmly (so it doesn't get sucked in) and see if it gets occasionally sucked up against the tailpipe. This would indicate an exhaust valve not seating.
kattz is offline   Reply With Quote
Help!!! Somebody Please!!!! Something Is Wrong!!! DeadBolt Enterprises South East Region Forum 14 03-04-2004 09:47 PM
Something is wrong with Greg's car..... again.... but very strange this time. GregUnd Texas Impreza Club Forum -- TXIC 28 05-22-2003 05:01 PM
I hit rev limiter by accident. Something is wrong... blackwrx127 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-13-2003 04:45 PM
('93-'01) I'm an idiot or something is wrong. Joncas Impreza Forum 16 04-21-2001 08:36 AM
Help! Something is wrong incorporeal Technical Forum Archive 8 08-10-2000 02:58 PM
