Old 07-01-2005, 08:28 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default When do I change the plugs?
I bought my 99 RS back in October with 103K miles on it. How do I know if it's time to change the spark plugs/wires?
Lachlan is offline   Reply With Quote
Old 07-01-2005, 09:05 PM   #2
IMPREZA619
Member#: 24289
hope your speed over
the Rival.
Change them regardless, its only 1.50 a plug and takes less than 15min to gap and install. And if the wires have never been changed you might want to do that too. Use a wire brush on the coil pack and clean off some of the corrosion on the contacts. Dont buy bosch plugs they suck on subarus. Use ngk/champion coppers or if you want, the oem subaru ones (also ngk i believe) Hope this helps.
IMPREZA619 is offline   Reply With Quote
Old 07-01-2005, 10:27 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
Thanks. I pulled out the #1 wire and found oil. Is that normal?
Old 07-01-2005, 11:18 PM   #4
Lachlan
Member#: 19470
1981 Brat GL
Holy incorrect spark gap, Batman! The ones I pulled out were at .065, .075, .075, and .085!
Old 07-01-2005, 11:24 PM   #5
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
The plugs are worn out and by the gaps well past time they should have been changed. The oil is probably the cover o-rings that seal the spark plug tubes leaking. So it's time for new plugs, cam cover gaskets and o-rings.
GuyLR is offline   Reply With Quote
How do you change the spark plug on #4 cylinder? evanejp1980 Legacy Forum 3 12-02-2009 10:57 AM
1 thing i notice today when doing oil change silver-RS Service & Maintenance 2 09-11-2006 08:29 AM
when doing oil change how long do you leave the oil to drain out? malibuda Service & Maintenance 38 11-07-2005 12:35 PM
When do I change the fluids? GHST Newbies & FAQs 10 12-22-2004 10:20 AM
How and when do I change transmission fluid? FatJoe Transmission (AT/MT) & Driveline 2 04-22-2003 12:43 PM
