Old 07-01-2005, 09:49 PM   #1
UltimateLurker
Member#: 82488
06 Lotus Exige
Default AccessPort Stage 1 to Stage 2 question...
OK, so I've got my down-pipe and I'm ready to go Stage 2 tomorrow, can you guys tell me if I've got this right? Current map is Stage 1 93 octane with no Real-Time map.
1. Connect white connector
2. Connect green connectors
3. Turn the key to the "ON" position
4. Go to "Change Base Map" & select Stage 2 93 oct
5. After reflash, scroll to "Show Current Map" to check it
6. Load Real-Time Stage 2 93 oct map?
7. Reset ECU?
8. Clear CEL codes?
9. Done?
Any help would be much appreciated .
UltimateLurker is offline   Reply With Quote
Old 07-01-2005, 10:13 PM   #2
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Subaru Banner
6. remove connectors
You don't have to load the real time map, but you can if
you want too - I did not.
No reset of ECU is needed.
There should be no CELs
You can check current map any time with out putting
on the connectors. I also think you can change real time
maps with out putting on the connectors.
MD04WRX is offline   Reply With Quote
Old 07-01-2005, 10:13 PM   #3
vinithing
Member#: 59414
05 STi
You do not have to reset your ECU. If you flash to stg2 93 base that will automatically be your realtime map. Make sure to disconnect all of the connectors! Have fun....
vinithing is offline   Reply With Quote
Old 07-01-2005, 10:38 PM   #4
UltimateLurker
Member#: 82488
06 Lotus Exige
Did I tell you guys that you RULE!!???!@?????!?!?!?@?!?!??!
Thanks
Old 07-02-2005, 10:42 AM   #5
2004blackwrx
Member#: 59883
2004 wrx
black java pearl
Cels will not need to be cleared because stage 2 automaticlly takes care of any of the typial cels you would see for the mods required
2004blackwrx is offline   Reply With Quote
Old 07-03-2005, 12:43 PM   #6
UltimateLurker
Member#: 82488
06 Lotus Exige
thanks. I had to put off going Stage 2 because the Helix DP does not mate directly to the stock resonator section, I now understand that I have to purchase a new resonator section that starts at 3" and tapers to 2.5" for the AB.
Old 07-03-2005, 01:25 PM   #7
flabele
Member#: 87475
2005 VF-34 / COBB
PSM SILVER ( not pms )
after u reset the ecu perform the vishnu reset. It works for me everytime.. Do a search and you will find out how to do it. peace.
flabele is offline   Reply With Quote
Old 07-03-2005, 04:48 PM   #8
Zumble
Member#: 34860
2005 Forester CGM
Just to be clear, you can only check the current Basemap not the current Realtime map using the AP. If you flashed a stage 1 93 oct map as base and then flashed the anti-theft realtime map the checked the maps, it will say Stage 1 93 oct. If you're not sure about which realtime map you're running, it's best to reflash with what you want.
Zumble is offline   Reply With Quote
stage 1 to stage 2 dumpstercrusher Mid Atlantic Impreza Club -- MAIC 28 08-16-2007 11:34 PM
Cobb stage 1 to stage 2 today... adoinfl AccessPort 13 07-22-2007 02:57 AM
Going from AP stage 1 to stage 2? bigwrxguy Engine Management & Tuning 10 06-24-2005 11:51 PM
Cobb Accessport Stage 1 to Stage 2? wrx2k4blue Engine Management & Tuning 13 08-13-2004 07:56 PM
? about TXS stage 1 to stage 2 sounds Tronner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-06-2002 07:37 PM
