Old 07-01-2005, 10:07 PM   #1
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Default Difference between USDM and Canadian models
So a while back I purchased a 92 Legacy Turbo Sedan that was originally imported to Canada. I was just wondering if you guys have noticed any differences from the USDM and the CDM.
A few things I noticed where the dash lights, and the day time running lights. I had a USDM Turbo before the CDM and noticed that instead of the standard “brake” when the emergency brake was engaged there was now a “!”.
One difference that I did like was the manual seat belts. The USDM got the cruddy automatic seat belts which were prone to failure.
I no longer have the car so I can’t really check to see if there were any other things that differed from the USDM version. I think I might have taken a picture of the dash lights, but I can’t seem to find it.
So what have you noticed?
subiekid is offline   Reply With Quote
Old 07-02-2005, 08:28 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Well from a wiring and drivetrain perspective, both USDM and CDM are the exact same. I have a CDM EJ20 drivetrain with a USDM ECU and wiring harness. In performing my swap, it was clear that these two RHD’s are the same.
I imagine you’ll only find minor changes between the model, most specifically geared towards the combination meter (instrument cluster) and the integrated micro-computer which is used to process sensor data (such as VSS) and present it to the instruments.
xcntrk75 is offline   Reply With Quote
Actual Differences between USDM and JDM Downpipes? SPEED6 Newbies & FAQs 34 12-02-2007 11:14 AM
Difference between USDM and JDM STi injectors txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-30-2005 05:25 PM
What's the difference between usdm and jdm v7 exhaust? callaway Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-04-2005 12:18 PM
difference between USDM and EDM power? PPower Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-23-2003 11:27 PM
Small difference between USDM and JDM I noticed pio!pio! STi Forum Archive 5 01-06-2003 08:59 PM
