Old 07-02-2005, 11:16 AM   #1
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Hesitation and Almost Stalling
1997 2.2ltr Subaru Outback Sport Wagon AWD/Auto
While sitting idle in traffic, car sometimes hesitate and acts as if it is going to cut off. Almost feel like an engine misfire or something. Checked ignition and #1 cylinde part that connects to the spark plugs had some greenish residue on it. Instead of sanding it down and cleaning it, I purchased a new one and installed it. Also changed spark plug wires and new plugs. New fuel filter was added as well. New vacuum hoses were added to the Minnam intake and tightened securely. Air filter was cleaned and the Maf sensor was spray cleaned with electrical cleaner and the bolts on it tightened snugly. Throttle body didn't have any excess oil or residue inside. PCV valve was changed out maybe 5k miles ago or so.
It does not hesitate once I start driving. This only happens while idle at a light.....sometimes. What could it be? Any suggestions on what else to troubleshoot. I'm trying to save the larger maintenance items for last like getting the injectors cleaned.
Kevin Thomas is offline   Reply With Quote
Old 07-02-2005, 11:23 AM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
AC kicking in maybe?
orndog is online now   Reply With Quote
Old 07-02-2005, 12:24 PM   #3
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
maybe try some of the injector cleaner you can buy at the store??
Jared
gtwagon941 is offline   Reply With Quote
Old 07-02-2005, 12:29 PM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
I get this, too, but it seems to be only when it's wet outside. I'm thinking that it's something to do with the IAC. I'm going to pull mine and lube it up when I remember to buy a new gasket for it.
LetItSnow is offline   Reply With Quote
Old 07-02-2005, 02:37 PM   #5
Kevin Thomas
Member#: 110
1989 1989 XT6
I forgot all about the idle air control valve. The car does have about 128k miles on it. It can not hurt to change it out. I will look into it. Thanks!
Hesitation and surging acceleration originalozzyo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-10-2010 03:52 PM
hesitation and stalling after fmic jakesurfin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 09-13-2009 11:28 AM
a beep and almost stall? mikeyp973 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-26-2008 03:04 PM
put stage 2 modifications on, CEL and almost stalls b0nd18t Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 06-24-2008 08:46 PM
UTEC installed.. and barely idle almost stalling.. Diversion Engine Management & Tuning 94 05-05-2005 09:42 AM
