Old 07-02-2005, 12:33 PM   #1
emyselfandi
Member#: 83701
Default wet dirvers side floor??
i have a 95 legacy sedan Lsi and for some reason the center of the floor is all wet on the drivers side. I thought that maybe the seals were loose on the windows but i can't see any water or wetness around the door side of the carpet. It seems to be wet dead center on the floor pan... Sun roof is water tight and i dont see any rust under the body.. Can somebody help me figure this out??? Wife wants a new car already and i'd rather fix the problem.... Thanks, Tim
emyselfandi is offline   Reply With Quote
Old 07-02-2005, 02:13 PM   #2
denigrad
Member#: 68666
2000 Impreza 2.5RS
Silverthorn Metallic
I had a similar problem with my 93 s10 pickup. You might want to check the seals on the windshield. However, the source for me was the main body seal between the firewall and the cab.(It might have been rust/rot damage, but I did not feel like ripping off the hood,fenders, cowl, etc... to check it.) I never got an estimate to get it fixed.(I just sold it to my Dad instead )
denigrad is offline   Reply With Quote
Old 07-02-2005, 03:01 PM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Could be at the firewall, could be the seals around the door frame.
I know when I powerwash my car water gets in near the bottom of the door frame due to a bad seal. Also I have leaking problems from the sunroof...but its not too bad. I'd say take the car to your local do it yourself car wash and go at it for a few minutes and then check to see if theres any water anyplace.
fibuz is offline   Reply With Quote
Old 07-08-2005, 11:39 PM   #4
blackbart
Member#: 57892
1994 Turbo Wagon
Varies with mood
I had the same problem, my doctor gave me a free sample of "Depends". They looked a little wierd at first but then I got the idea to wear my pants over them.
Sorry 'bout this, I'm tired and need some sleep.....
blackbart is offline   Reply With Quote
Old 07-09-2005, 10:35 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
For the original post, do you have a sunroof? They are known to plug up the drain that is in the front corners of the sunroof opening.
When these plug up, the water runs down the A-piller and onto the floor.
Old 07-09-2005, 11:21 AM   #6
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
I had this happen in my Ford Escorts and it was related to an AC hose/drain that was clogged. The clog (a bunch of pine needles and other miscellaneous crapped sucked in from the out side) caused moisture to condensate onto my passenger's side rugs. Happened in two Escorts I've owned.
ScoobyNubieToo! is offline   Reply With Quote
Old 07-09-2005, 12:17 PM   #7
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
None of the above....... There is a drain hole in the rocker panel. If iuf get clogged with crap then it needs to be flushed out. find the little rubber plug on the inside top of the rocker paneland take it out. shoot a very high pressure stream of water into that hole and you will see all sorts of junk come out. Thats the fix.
Russell Rogers is offline   Reply With Quote
Old 07-09-2005, 09:18 PM   #8
emyselfandi
Member#: 83701
dude thanks.. that's what I was looking for. I"ll check it out tomorrow after the huricane passes....
WTB dirvers side foglight 2002 wrx azarchie South West Impreza Club Forum -- SWIC 0 05-06-2008 11:53 PM
EASY FIX: wet drivers side floor gbelli Legacy Forum 1 06-05-2004 03:36 AM
Leak making drivers side floor wet gbelli Legacy Forum 10 11-04-2003 01:57 PM
('93-'01) Carpet on Passenger side floor?? THEMUSH Impreza Forum 1 10-21-2001 02:32 PM
