Old 07-02-2005, 08:02 PM   #1
Lavery
Member#: 77896
98 impreza 2.5rs
Default when to change clutch? (N00b)
Sounds like a rediculous question, but this is my first manual transmission and second car (19yrs old). The car has 88k miles and I've had it for two years. I don't believe it has ever been changed. Should I just keep the stock one until I feel "slippage" or would it be worth while to go ahead and swap it out this summer while i have time to do it myself. I'll do upgraded clutch and lightweight flywheel if thats the case.
thanks for any input. <embarassed>
Luke
Lavery is offline   Reply With Quote
Old 07-02-2005, 08:42 PM   #2
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
Well, it depends, do you ant performance or just a daily driver and trying to save money?
It all depends on how you and the person before you drove the car. I.E. slipping the clutch too much, dumping the clutch, those sorts of things.
So it might be a good idea if you want performance, since it apparently has never been changed.
Millencolin! is offline   Reply With Quote
Old 07-03-2005, 01:14 AM   #3
Lavery
Member#: 77896
98 impreza 2.5rs
I've got about all the bolt-ons you can get (full exhaust, intake, pulley) so yes I want performance. I'm pretty good on it, but it has seen some track days. I ran a 15.6 in the 1/4. I've seen people with lesser set-ups run 15.2s. I'm thinking I could benifit from a new one.
Old 07-03-2005, 07:52 AM   #4
Slack
Member#: 17548
If you're fine with the stock clutch, just leave it in there till it starts to slip.
Mick
Slack is offline   Reply With Quote
When to change the 6-speed transmission fluid - What brand to use? garboplateNY88 Service & Maintenance 2 10-11-2007 04:48 PM
When to change oil when tracking car? Pete Holt Service & Maintenance 6 03-26-2006 11:33 PM
When to change spark plugs & what brand to use? Bradus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-01-2004 01:53 PM
When to change to synth motor oil. tntmskfor Service & Maintenance 8 11-28-2002 10:12 PM
How to determine when to change brakepads? Robmat Service & Maintenance 2 04-29-2002 01:18 AM
