Old 07-02-2005, 10:18 PM   #1
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Default CEL Code 1507
P1507 Idle control system malfunction (fail-safe)
How do I fix this, what part needs to be replaced? Do I even have to worry about this? Cost?
SuBart is offline   Reply With Quote
Old 07-03-2005, 06:43 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This code indicates that the ECU is unable to obtain the desired engine idle. The usual cause of this is a sticking or otherwise failed idle air controller. Sometimes the IAC can be successfully cleaned, if this doesn't work it may need to be replaced.
Also look for vacuum leaks and other conditions that affect the idle speed.
Old 07-28-2005, 09:29 AM   #3
figgskzoo
Member#: 82547
2010 Forester
Default IAC is toasted, prolly
It's $300 bux at the dealer, dude. Try a WTB first...
figgskzoo is offline   Reply With Quote
CEL code 1507 wms291 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2007 06:34 PM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
Check Engine Code 1507 OArmijo Service & Maintenance 4 09-02-2003 12:23 PM
Cel Code 1507 OArmijo Normally Aspirated Powertrain 1 07-13-2002 06:40 PM
