Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 07-03-2005, 06:17 AM   #1
syncrosubaru
Member#: 89399
2005 wrx wagon
Default wrx headlight beam height
I looked and my headlight on my wrx wagon say 6%. I was wondering if it was possible to manually adjust the height. In my opinion they do not shine high enough. The A4 wagon I used to have, you could adjust the height with a screwdriver.
syncrosubaru is offline   Reply With Quote
Old 07-03-2005, 03:51 PM   #2
WRXRgr
Member#: 54942
2004 WRX
Should be...my MY04 WRX sedan has height and lateral adjustments.
Look at back of the lamp housings, there are two "towers" extending from the backside...one is for vertical adjustment, the other is lateral. The actual adjuster bolts are covered by black plastic caps, that pry off, once you lift the little tab free.
WRXRgr is offline   Reply With Quote
Old 07-04-2005, 04:26 AM   #3
syncrosubaru
Member#: 89399
2005 wrx wagon
Thanks. I will check it out.
It actually says 1.2%, not 6%. I was wrong on that.
I guess nobody else knows this, or they are happy with headlights shinning low?
Old 07-21-2005, 09:28 AM   #4
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
I moved my headlights up on my '05 WRX the first month I had it. It helped out a lot. I also adjusted my fog/driving lights up a bit too. They were way too low stock.
BTW what does the 1.2% designate? Is this the amount of play that the adjustments can provide? Or is it something else?
rebos123 is offline   Reply With Quote
Old 07-21-2005, 01:21 PM   #5
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
O4 wrx, support beam, headlight right side 02 wrx roar Exterior/Styling 8 03-28-2011 10:24 PM
Light beam height adjsutment? sonic03dz Electrical & Lighting 5 10-21-2008 05:47 PM
02-03 WRX Double Beam Euro Headlights 500whp.com Exterior/Styling 6 02-24-2005 09:06 AM
02-03 dual beam wrx headlights! unfadeable wagon Private 'For Sale' Classifieds 8 11-14-2004 08:40 PM
WRX Dual Beam Conversion Headlights- $190 shipped tokigiracing Vendor 'Group Buy' Classifieds 77 08-28-2003 12:24 PM
