Old 07-03-2005, 03:31 PM   #1
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Default A little UTEC help, please.
XS450
Perrin modified injectors
Spearco TMIC
TurboXS Stealth back w/cat
UTEC
I知 in the process of upping the boost a little. I知 not seeing any problems with the new boost curve going from 2K from 4th and rowing through the gears to about 5Kin 6th. It stills needs a little smoothing in terms of both boost and fueling. Here are a couple of plots showing a 4th to 5th pull.
The problem is that I知 seeing a little knock rolling into 5th while cruising. It looks like the ECU is not seeing it but UTEC is pulling timing. I知 already running at 10.8:1 AFR and 12.5 degree with the EGT in the 1400s. I知 going to pull another .5 to 1 degree out and see what happens. Are there anybody running less than 12 degrees in the low spot in their timing map? Do you guys think it could be that I知 building boost too aggressively?
Code:
 2641  -3.6 2.6  19  00    00   +40.4   10.9 ECU.   +0.5 ECU.   2.3  14.45
 2679  -3.6 2.6  19  00    00   +40.5   10.4 ECU.   +0.5 ECU.   2.3  14.58
 2666  -3.6 2.6  19  00    00   +40.4   10.5 ECU.   +0.5 ECU.   2.3  14.65
 2656  -3.4 2.6  19  00    00   +40.3    8.8 ECU.   +0.5 ECU.   2.3  14.61
 2681  -3.2 2.9  33  10    00   +38.7   14.6 +32.0  +0.1 350.00 2.6  14.58
 2710  -1.8 3.0  40  10    00   +31.7   14.9 +32.0  +0.1 350.00 2.6  14.58
 2725  -0.2 3.0  43  20    00   +29.2   15.8 +25.0  -1.0 350.00 2.7  14.58
 2714  +1.5 3.1  45  20    00   +28.9   16.8 +25.0  -1.8 345.00 2.7  14.30
 2763  +3.3 3.2  50  30    00   +27.7   18.0 +19.0  -3.1 345.00 2.8  13.95
 2827  +4.3 3.2  52  30    00   +27.7   18.4 +19.0  -3.1 345.00 2.8  13.47
 2836  +5.5 3.4  55  40    00   +27.0   19.8 +17.3  -2.8 345.00 2.9  13.23
 2873  +6.6 3.4  59  40    00   +28.2   20.5 +17.3  -2.9 345.00 2.9  13.25
 2942  +7.8 3.5  65  50    00   +26.6   22.3 +15.8  -1.6 345.00 3.0  13.09
 2896  +9.2 3.5  71  50    00   +23.7   24.0 +15.7  -1.9 345.00 3.1  12.78
 3049 +10.2 3.7  71  60    00   +19.4   27.9 +14.0  +0.3 345.00 3.1  12.52
 3072 +11.5 3.7  76  60    00   +17.2   30.5 +14.0  +0.4 345.00 3.2  12.09
 2986 +12.7 3.8  78  70    00   +15.4   32.6 +13.3  +0.4 345.00 3.3  11.43
 3147 +13.9 3.9  81  80    00   +14.8   34.8 +12.9  +0.3 345.00 3.3  10.96
 3205 +15.1 3.8  81  80    00   +13.5   36.4 +12.5  +0.6 345.00 3.4  10.89
 3236 +16.6 4.0  81  80    01   +12.8   37.4  +9.7  +0.6 343.00 3.4  10.89
 3280 +17.6 4.0  84  90    01   +12.1   39.6  +8.0  +0.9 343.00 3.5  10.86
 3310 +17.4 4.0  84  80    00   +13.4   37.7  +8.5  +0.8 343.00 3.5  10.86
 3360 +17.4 4.0  84  80    00   +12.5   41.9  +8.5  +0.7 343.00 3.5  10.93
Code:
 2038  +0.2 2.8  52  10    00   +33.7    9.4 +32.0  -0.9 350.00 2.4  14.61
 2119  +1.1 2.7  78  20    00   +32.3    9.9 +26.5  -1.3 350.00 2.4  14.74
 2096  +1.9 2.7  95  20    00   +31.0   10.5 +26.3  -1.4 350.00 2.4  14.61
 2167  +2.7 2.8 100  20    00   +31.4   10.1 +26.4  -1.3 350.00 2.4  14.30
 2171  +2.9 2.8 100  20    00   +31.4   10.4 +26.1  -1.5 350.00 2.5  14.15
 2246  +3.3 2.9 100  20    00   +32.8   10.6 +26.1  -1.6 350.00 2.4  14.22
 2249  +3.5 2.8 100  20    00   +32.8   10.9 +25.9  -1.1 350.00 2.4  14.30
 2306  +3.9 2.8 100  20    00   +33.0   11.4 +25.8  -1.7 350.00 2.4  14.22
 2324  +3.9 2.9 100  20    00   +32.6   11.8 +22.2  -1.8 350.00 2.5  14.18
 2355  +4.1 3.0 100  30    00   +32.9   12.5 +22.0  -1.9 350.00 2.5  14.15
 2410  +4.5 3.0 100  30    00   +32.5   12.0 +22.0  -2.0 350.00 2.6  14.15
 2415  +4.9 3.0 100  30    00   +29.3   12.6 +21.8  -2.1 350.00 2.6  14.11
 2447  +5.3 3.0 100  30    00   +28.4   13.2 +21.6  -2.1 350.00 2.7  14.30
 2485  +5.5 3.1 100  30    00   +27.7   14.1 +21.0  -2.2 350.00 2.6  14.22
 2510  +5.9 3.1 100  30    00   +27.9   14.4 +20.8  -2.2 350.00 2.7  14.08
 2594  +6.4 3.1 100  40    00   +27.3   15.3 +18.7  -1.8 350.00 2.7  14.00
 2622  +6.8 3.1 100  40    00   +25.6   15.9 +18.4  -2.0 350.00 2.8  13.72
 2651  +7.2 3.2 100  40    00   +25.4   16.9 +18.1  -1.8 350.00 2.7  13.53
 2714  +7.6 3.3 100  40    00   +27.0   17.8 +17.8  -2.5 350.00 2.8  13.47
 2752  +8.0 3.3 100  40    00   +26.5   18.2 +17.5  -2.8 345.00 2.9  13.56
 2824  +8.4 3.4 100  50    00   +24.7   21.7 +16.3  -1.2 345.00 2.9  13.56
 2834  +9.4 3.5 100  50    00   +23.6   22.6 +16.2  -1.4 345.00 3.0  13.12
 2926 +10.2 3.6 100  60    00   +21.6   25.4 +14.3  +0.5 345.00 3.1  12.59
 2944 +11.3 3.6 100  60    00   +17.9   27.5 +14.2  +0.5 345.00 3.1  12.21
 3005 +12.3 3.7 100  60    00   +16.3   29.8 +14.0  +0.4 345.00 3.2  11.73
 3077 +13.1 3.8 100  70    00   +15.4   32.4 +13.4  +0.4 345.00 3.2  11.34
 3126 +14.5 3.8  99  80    00   +14.1   35.2 +12.9  +0.6 345.00 3.4  11.12
 3118 +15.7 3.9  99  80    00   +12.8   34.9 +12.5  +0.6 345.00 3.4  11.01
 3277 +17.0 3.9  99  90    00   +13.1   37.6 +12.0  +0.6 343.00 3.4  10.83
 3271 +17.6 3.9  99  90    00   +15.0   37.5 +12.0  +0.8 343.00 3.4  10.73
 3370 +17.8 4.0  99  80    00   +13.6   39.6 +12.5  +0.7 343.00 3.5  10.80
 3436 +17.8 4.0  99  80    00   +14.0   40.6 +12.5  +0.6 343.00 3.5  10.83
 3486 +17.4 4.0  99  80    02   +13.5   41.9  +8.5  +0.5 343.00 3.5  10.80
 3561 +17.6 4.0  99  90    00   +13.6   44.1  +8.0  +0.4 342.00 3.6  10.86
 3635 +17.6 4.1  99  80    00   +17.7   43.0  +8.5  -0.5 342.00 3.5  10.81
 3635 +17.0 4.1  47  80    00   +18.1   42.0  +8.5  -0.4 342.00 3.5  10.78
StiDreams is offline   Reply With Quote
Old 07-04-2005, 12:22 PM   #2
Tgui
Member#: 44771
I'll look through my logs when I get home from work.
Tgui is offline   Reply With Quote
Old 07-05-2005, 10:39 AM   #3
Tgui
Member#: 44771
Take a look at my post on sanity checking my tuning, there is a log included. Might be able to get some timing ideas, or not
Old 07-05-2005, 11:19 AM   #4
wrex03
Member#: 29963
04 sti
It probably is heat soak from the tmic. I have that issue every once in awhile. 5th gear pull from a FP green and txs tmic. I've leaned out the fuel a little since this log, but the timing is still pretty much the same.
Code:
2297  -9.1 2.3  16  00    00   +43.4    5.8 ECU.   +1.0 ECU.   2.1  14.74
 2322  -7.7 2.5  23  10    00   +44.7    8.6 +41.0  +3.6   1.00 2.4  14.25
 2331  -5.5 2.7  35  10    00   +38.7   11.8 +41.0  +3.6   1.00 2.5  13.92
 2365  -3.0 2.7  44  10    00   +37.8   12.6 +41.0  +3.6   1.00 2.5  13.50
 2401  -1.0 2.8  53  10    00   +36.7   13.4 +41.0  +3.6  30.70 2.5  12.71
 2431  +0.2 2.8  61  10    00   +35.9   13.7 +41.0  +3.6 103.00 2.6  12.27
 2450  +1.1 2.8  69  10    00   +34.6   14.4 +41.0  +3.6 127.00 2.7  12.18
 2474  +1.7 2.9  74  20    00   +33.1   15.0 +30.4  +3.7 278.00 2.7  12.27
 2536  +2.5 2.9  87  20    00   +31.3   15.6 +30.0  +3.7 500.00 2.8  12.39
 2566  +3.1 3.0  90  20    00   +29.6   16.7 +30.2  +3.7 500.00 2.8  12.34
 2618  +3.7 3.0  93  20    00   +28.4   17.1 +30.4  +3.7 500.00 2.9  12.18
 2639  +4.5 3.0  98  30    00   +27.2   18.1 +25.0  +3.7 500.00 2.9  12.09
 2651  +5.1 3.2  99  30    00   +25.9   19.1 +25.0  +3.6 500.00 2.9  11.96
 2686  +6.2 3.2  98  30    00   +24.9   20.5 +25.0  +3.6 500.00 3.0  11.84
 2738  +7.0 3.3  98  40    00   +24.0   23.1 +22.0  +3.0 500.00 3.0  11.68
 2812  +7.6 3.3  99  40    00   +23.0   24.1 +22.1  +3.0 500.00 3.0  11.58
 2886  +8.6 3.5  98  40    00   +22.0   25.7 +22.2  +3.0 500.00 3.1  11.30
 2901  +9.2 3.5  99  50    00   +20.4   26.8 +19.2  +1.8 500.00 3.1  10.90
 2973 +10.4 3.5  98  50    00   +20.3   29.8 +19.0  +1.7 240.00 3.2  10.78
 3013 +11.5 3.7  98  60    00   +19.2   32.1 +14.9  +1.7 240.00 3.2  10.83
 3100 +12.7 3.8  99  60    00   +17.4   34.7 +14.6  +1.7 240.00 3.3  10.81
 3106 +14.1 3.7  98  70    00   +16.2   36.1 +13.0  +1.9 240.00 3.4  10.74
 3153 +15.5 3.9  99  70    00   +14.7   37.8 +13.0  +1.9 240.00 3.5  10.78
 3264 +17.0 3.8  98  80    00   +15.0   40.0 +12.0  +1.5 240.00 3.4  10.78
 3316 +18.2 4.0  99  80    00   +15.5   41.3 +12.1  +1.6 240.00 3.5  10.67
 3377 +18.8 4.0  98  80    00   +15.3   42.4 +12.2  +1.6 240.00 3.5  10.67
 3408 +19.4 4.0  98  80    00   +17.5   42.5 +12.4  +1.5 240.00 3.6  10.67
 3494 +19.4 4.0  98  80    00   +17.3   43.8 +12.5  +1.2 240.00 3.6  10.65
 3576 +19.8 4.1  98  80    00   +18.1   45.3 +12.4  +1.4 240.00 3.6  10.73
 3642 +20.0 4.0  98  90    00   +19.7   45.8 +12.0  +0.6 240.00 3.5  10.65
 3671 +20.2 4.1  98  90    00   +21.8   44.7 +12.0  +0.1 240.00 3.6  10.55
 3703 +20.4 4.1  99  80    00   +22.6   47.3 +12.1  +0.0 240.00 3.6  10.65
 3779 +20.0 4.1  98  80    00   +21.9   49.9 +12.0  +1.1 240.00 3.7  10.73
wrex03 is offline   Reply With Quote
Old 07-05-2005, 06:53 PM   #5
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
You're knocking in pretty much the same location. I would drop the timing to 12 from what looks like 12.5. I run on crappy cali gas as well and at that point I have to run 12 or I knock.
I also run closer to 10.5:1 on 91, but if you can get away with 10.8 go for it. Maybe try richening slightly before reducing timing? If when at 10.5:1 you are still knocking, then you either have to lower boost or timing.
Rob
dosage0 is offline   Reply With Quote
Old 07-05-2005, 06:55 PM   #6
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Thanks for the input everybody. I'm going to try 12 first then go to lower AFR if that doesn't fix it.
Old 07-05-2005, 09:56 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
Ya might wanna also try lowering the boost, adding some octange booster, or looking into water/alc injection.
peace
Old 07-06-2005, 12:41 PM   #8
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I know it's time to go that route. I just have to get off my ass and do it. That and find the time to do a full retune with water. I guess it's time to order the 2D.
A little utec help.. kokob North West Impreza Club Forum -- NWIC 2 12-04-2008 07:21 PM
A little song help please... BigWrecKs Off-Topic 5 05-11-2006 01:51 AM
a little Utec help WrXaWd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-24-2005 03:43 PM
Little UTEC help please StiDreams Engine Management & Tuning 9 03-24-2005 12:21 PM
I feel stupid...little Cisco help please JGard Off-Topic 28 02-09-2003 03:15 PM
