Old 07-03-2005, 06:10 PM   #1
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
Default rallitek chip
hi,
whre can i find out what kind of additional power it yields?
thanks.
J
hendo2.5 is offline   Reply With Quote
Old 07-03-2005, 07:11 PM   #2
Handsdown
Member#: 29355
rallitek.com
but the general notion around here is that it's a lot of money and there's just not a lot of performance to be gained by it.
Handsdown is offline   Reply With Quote
Old 07-03-2005, 07:20 PM   #3
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Originally Posted by Handsdown
rallitek.com
Really? 10whp/10tq isn't too bad. And it appears that when you have additional supporting mods there may be even more to gain.
http://rallitek.net/forums/showthread.php?t=1674
Jared
gtwagon941 is offline   Reply With Quote
Old 07-03-2005, 07:28 PM   #4
Handsdown
Member#: 29355
oh wow, when it was still in development they were saying it would be at least 700 bucks. for <400 it's actually not that bad of a deal. i stand corrected.
Old 07-03-2005, 09:11 PM   #5
AWDsub
Member#: 56303
2010 Legacy GT
Originally Posted by hendo2.5
hi,
J
Are you asking about Rallitek's Perfect Power? If so, then you will not find a cheaper engine management that actually works than the Perfect Power. If you have any of the basic mods you should defineately considering some sort of engine management like Perfect Power. I have emphasized this many times on other threads because of the huge gains that I have seen with my own car.
AWDsub is offline   Reply With Quote
Old 07-03-2005, 09:25 PM   #6
AlpoRS
Member#: 81338
2005 2.5 RS Wagon
Crystal Gray Metallic
I agree, the perfect power is amazing, i have it on my 05 rs...even stock, i could feel a damn good difference for just typing in a few numbers. I never got to experience it with a good set up of bolt ons, but if you do have intake and exhaust done, i definitely recommend you get the PP to correct your air fuel ratios and make your ride even sweeter.
AlpoRS is offline   Reply With Quote
Old 07-03-2005, 09:58 PM   #7
Bud Brown
Member#: 90248
hmm, i may look into this.
Bud Brown is offline   Reply With Quote
Old 07-03-2005, 10:24 PM   #8
piker28
Member#: 22664
yeaaaa but then you need the car dynoed and tuned, but depending where you live price for that can vary
on the east coast by me itll cost a ton to dyno and wait for awhile
piker28 is offline   Reply With Quote
Old 07-03-2005, 10:33 PM   #9
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
how does it affect the warranty?
Old 07-03-2005, 10:35 PM   #10
piker28
Member#: 22664
your joking right...
this is wired into your ecu, wave bye bye to warranty since id mean changin AF ratios and what not to the engine
Old 07-03-2005, 10:37 PM   #11
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
VOID
Some are PnP but the 400 one is wired in....so you'll never not know beacuse all they need to do is look at the wiring and see it's all hacked up...
holland_patrick is offline   Reply With Quote
Old 07-04-2005, 10:00 AM   #12
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
rats
Old 07-06-2005, 07:15 PM   #13
DragonRM
Member#: 14365
I have the Perfect Power too... love it... I tried to do a clamp based version first but it didn't work out too well. I did get a bridge from them though to bypass the ecu if you ever needed to. As far as warrenty issues go... I always heard they can't legally void it unless the part they're replacing was shown to be damaged by the direct fault of a mod. And then it's not the full warrenty just on that part. So say if you did ecu mods and had a suspension problem that was under it they'd still have to fix it.
DragonRM is offline   Reply With Quote
Old 07-07-2005, 02:23 PM   #14
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Does anyone make a patch cord with two connectors and a few inches of wire so that the soldering can be done to the patch cord. Not the factory harness? That way is can be removed. I am sure someone has thought of this but why is it not done? It seems it would be ideal.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 07-07-2005, 02:29 PM   #15
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Peace,
Greg
I think that someone mentioned this in the rallitek forumn, but the problem was that if one of the wires were to come loose, your could really screw up your tune. It still seems like a good idea to me though, but I am one of those worries too
impr25rs is offline   Reply With Quote
Old 07-07-2005, 02:33 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
So the big questions I have are:
A: does it remove CELs?
B: can you still do OBD-ii emissions testing with it in place?
Old 07-07-2005, 02:36 PM   #17
impr25rs
Member#: 60162
04 Aspen RS
I know that it doesn't remove CELs. As for the OBD-II testing I don't know, I would like to know too. We need Rallitek to chime in and give us some more lowdown.
Old 07-07-2005, 04:03 PM   #18
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I have the PerfectPower with the Secret Weapon intake, great combo! I got the PP first, and it makes a very noticable difference. Peviously, I had a ProECM on it, and the PP blows that away.
As for the OBD-II testing, yes, you can still do the emissions testing with it. It alters the siganals the ECU sees, but the ECU is still there and working, so it's no problem.
Also, for tuning, you don' have to dyno tune it. If you have a lapyop, you can datalog and go for a drive, then watch the playback, and tune it yourself. That's what I do, and it's pretty easy to use the software.
HondaH8er is offline   Reply With Quote
Old 07-07-2005, 04:09 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
I will have to seriously consider this route. Unless the sky falls and Cobb has their reflash available by their meet in September, I think Ralli-tek may get my hard earned dollars...
Old 07-07-2005, 04:20 PM   #20
impr25rs
Member#: 60162
04 Aspen RS
Thanks for the info. I could not remember if the OBD-II testing was an issue. I had heard that tunin the PP with a laptop was pretty straight forward, good to know.
Old 07-07-2005, 05:44 PM   #21
DragonRM
Member#: 14365
I don't have a CEL with mine... if you're getting a CEL otherwise you'll need some type of fix... emmissions should pass since the fuel ratio is cleaner and all the obd sensors still work.
My friend Troy and I tried to do the clamp/bypass route so we wouldn't have to solder... just use vampire clamps... didn't work... this unit is MUCH more stable soldered. The tuning software is awesome and a bit more straight forward than a Link but does everything in the open loop you'd need it to. Also when the SMT7 comes out you can run both at the same time (according to perfect power) and use the unique features from both chips... and I think the 7 will allow closed loop and is a bit more geared towards turbo apps. It's a freaking awesome chip hands down
Old 07-08-2005, 10:32 AM   #22
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
No worries. I already have dyno tuned/tested maps for most setups. Granted a bit more power can usually be had by a custom dyno tune, but RalliTEK has already been building maps.
One of my favorite features in our RalliTEK PerfectPower is the data logger, and the very easy to use windows software. You get to play back everything in slow motion or frame by frame. Very cool!
More info in the PerfectPower / RalliTuning areas of www.rallitek.net
-Sean S.
RalliTEK Subaru Performance Inc.
www.RalliTEK.com / www.rallitek.net
Rallitek.com is offline   Reply With Quote
Old 07-08-2005, 11:29 AM   #23
impr25rs
Member#: 60162
04 Aspen RS
Sean,
What kind of information do you get when you data log? What are the benefits of the new SMT7 that will be coming out vs the SMT6? Thanks for posting.
Old 07-08-2005, 11:31 AM   #24
gc8impreza00
Member#: 81107
2000 2.5rs
silverthorn/Carbon Fiber
P/P has too many benefits to list. For the price its worth it. guarenteed
gc8impreza00 is offline   Reply With Quote
Old 07-08-2005, 12:43 PM   #25
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Originally Posted by impr25rs
Sean,
The new one is more for turbo specific apps. It will be quite a bit more money, and I don't think it is really going to offer benefits to N/A people.
Jared
Hello, Chip. Chip, meet hood. Hood, meet chip. Frinklemur Car Care & Detailing 12 01-04-2010 12:09 PM
I'm hungry. Anyone for chipped beef or better yet, chipped chicken? HoRo1 Political Playground 16 12-03-2003 01:53 AM
chips chips chips... ezekiel044 Tri-State Area Forum 7 02-21-2003 06:24 PM
Chips? Anyone for some chips? SoCalScooby General Forum Archive 4 11-15-2000 05:13 PM
